Re: Hi, my direct drive coupling is broken, can you put...
Hi Bob. Welcome to FixYa I am Kelly.
Boy seems to be several of these today. Here is a video that is a bit long winded but does a bang up job of "how to perform the motor coupler replacement.
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength. CAD$12.81
It has to do with the motherboard. If it isn't a USB 2.0 port it will not recognize the drive you will have to change the motherboard or the cheaper thing to do is put a PCI to USB card in the computer.I had the same problem with a buddy's computer.
the wigwag is bad, which has to be replaced,, you need to find out what caused the drive coupling to fail in the first place & fix that problem or else you will have the same problem again..
There is no belt on this machine. It uses a direct drive coupling between the motor and transmission. Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor. Remove the motor then remove the broken drive coupling(3 parts). Replace the part and re-assemble the washer.
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly. Faulty Direct Drive Coupling The
Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore
brands washing machines utilize a small, relatively inexpensive direct
drive motor coupling. It's plastic and rubber and is mounted to the
shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Water Level Switch
If
the water level switch is not resetting once the water is drain, power
will not be available to operate the motor during spin. Check the water
level switch for proper operation.
Thank You For trusting us with your question Please remember to leave a rating before you leave!
You said, when the washer is going into spin cycle it makes a loud clunking
noise. You are wondering if this could be the brakes or possibly the
pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate) The
direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading. it can also be a broken spring or strut dependping on your washes make and type
