Cars & Trucks Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a short hiss sound almost like an air leak coming from the front drivers side wheel. Its not an air leak
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
461
Points
Check the brake pads. They may be worn down and the brake warnings are hitting the rotor. If they're ok, the housing around the rotors may be hitting the rotor.
Jonah Oneal
Level 3:
  • Chevrolet Master 14,092 Answers
Jonah Oneal
Chevrolet Master
Level 3:
Answers
14092
Questions
0
Helped
7241777
Points
44533
CHECK THE TIRE AIR STEM.I HAVE SEEN THEM LEAKING.I HEARD A HISSING NOISE TOOK TIRE OFF SPRAY SOAP WATER SOLUTION ON IT LOOKING FOR A AIR LEAK.DID NOT SEE IT UNTIL WHEN I PUT HUB CAP ON.HOLE THAT THE AIR STEM GOES THROUGH HIT AGAINST AIR STEM HISSING GOT WORSER LOUDER THEN I FOUND WHERE LEAK WAS.SO CHECK AIR STEM TO TIRE MOVE IT A LITTLE SEE IF YOU HEAR HISS NOISE.
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
2helpful
2answers
Recharged AC, blew cold for 1 day then heard hiss near driver tire and now no cold air.
Whenever you add Freon,you are suppose to leak test first.Your compressor is good,you have a leak somewhere.A good place to take it to is Midas,they changed my freon over from the old stuff to the new R-134a,they leak test it first,that is rule 1 when adding freon.
I posted a question about my 2000 mazda mpv when I turn on the heat in the front it blows hot on passenger side but not on driver side in fron by steering wheel
i cant give a direct answer i can only ask questions has anyone been under the dash put radio in heater core anything and knocked the vents loose do you hear air hissing or vacumm leak check fuse box for heater vents a/c vents blown fuse look under hood if you hear air look for loose hose going to firewall
87 chevy caprice A/C vent not opening
Depends on what is clicking. The engine vac opens blend doors under the dash. It could be one of the vac pots or a blend door is sticking. Normally the hissing noise means you have a leak, but a leak usually does not fix itself.
1helpful
Hissing sound like air from a tire coming from underneath rear driver's side
Sounds like you have something rubbing, since you are not loosing air and there is nothing else to hiss,, an exhaust leak would have a different sound. I have seen debris get wedged in the brakes and make a noise when you are underway. The sound would vary, depending on what sort of debris it is. I would remove the wheel and look for the culprit. Your brakes may need to be religned as well. Sometimes the audible brake wear sensor will make a noise like that. Good Luck! I hope this is very helpful!
Leaking coolant
Sound like a leaking hose to me or a leaking water pump, for me to help I need to know exactly what's leaking. Check it out and let me know. Good luck nd thanks for using FIX YA
1helpful
2003 forester - there is water leaking in the front passenger side floor when the air conditioner is running. sometimes a hissing sound also in the same area.
You need to clear the condenstate drain for the AC evaporator core, it is under the car, as far as the hissing, sounds like a vacuum leak, look for a disconnected small hose around the area of the noise.
Hissing noise coming from rear passenger side
yes that is the expansion valve! there is a hissing sound from the restriction in it for a pressure drop thats what makes the a/c cold the hissing is normal
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
