Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Hotpoint sy36x oven manual need to get oven of auto and put it onto manual
Posted by susanroge200 on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
Hello.
Go toi the following site for the info you need.
WWW.HOTPOPINTSERVICE.CO.UK
In the menu on the left, click on---Hotpoint user manuals, then in the search box on the right, enter your model number in CAPITAL letters without spaces, and download the user instructions.
This should solve your problem.
Posted on Feb 15, 2011
Faulty Hotpoint Forno sy36x/1.
Faulty switch operation may have caused the grill and oven elements to fail open. A continuity check would confirm this.
Sep 18, 2018 | Hotpoint Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36x display works but fan and element not working, connections seem ok
You need to ascertain that the components are getting a supply to them.
You will have to remove the oven from the housing, and remove the rear cover to check for supply to fan and element.
Jan 05, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My hotpoint sy36x cooker has just stopped working , the clock on the front stilll works but when i turn the button to turn on it doesnt do anything, when i tap the front left of the top panel it comes on...
Sounds like it could be could be due to a bad or loose connection..
You need to access the control panel, and check the connections.
If the oven is built in, then you will have to remove it from the unit.
Hope this helps.
Dec 15, 2009 | Hotpoint SY36 Style Line Stainless Steel...
How do you set the clock on hotpoint forno sy36x
HOTPOINT FORNO OVEN IS SET ON DEMO MODE HOW DO YOU DISABLE THIS
Oct 10, 2009 | Ovens
Just info plz sy36x
In your browser bar type in hotpoint user manuals
Then in the drop down list ,click on hotpoint manuals- user guides.
Then enter your model in the search box, and you can download the manual to your hard drive or send it to your printer..
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint BU62 display works but nothing else does.
If the display is flashing auto, then you need to reset it to manual, otherwise oven will not work,
The grill should still work regardless..If you have your handbook, refer to (What if something goes wrong).
If no hand book, type in HOTPOINT USER MANUALS in your browser bar, and follow the links.
Please leave feedback
Dec 02, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
663 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
