Grilling Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model # 463240904 ignitor stopped firing even after replacing battery?
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Feb 15, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103393
Points
14643
First, be sure you have the battery turned the right way. Generally the Positive Tip (+) should be facing up. Yours may be the opposite, so try it both ways. Also, when you remove the battery look inside the holder for signs of corrosion. If there is some, do your best to clean it out with a Q-Tip soaked in WD-40.
If none of the above seems to solve the problem, look for loose wires from the Ignitor button assembly to the Ignitor Elements (Tips) in the grill. Also, the Ignitor Elements at each burner in the grill may be covered with grease, which will prevent them from firing. If you see that, clean them with alcohol.
Those are the basic things that cause a battery operated ignitor to fail.
Hope this helps to solve your problem. Please let me know.
The gas valve will not fire, the ignitor glows but no fire from gas valve
replace your ignitor even if it is glow there is current that need to pass in the ignitor wire and if it is not getting to that current it will not kick on the gas valve , even if it is glowing.
if it is more then 4 years it is that :)
Mar 26, 2011 • Dryers
Gas oven on Kenmore range model 362-75191890 went off midway through roasting Thanksgiving turkey. There seems to be no gas getting to the oven burner, even though the range top burners fire up nicely.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Gas oven stopped working it heats up to 100 like it is supposed to then there is no whoosh sound and no futher heating .yes there is gas. it did this once before and then worked like it was supposed to...
Every time I have done this repair, the problem was the ignitor, even if it is glowing. Replace your oven ignitor, ask the parts company if there is a cheaper generic ignitor for your model. You could have a bad valve or a sensor, but since they came out with these ignitor models 12-15 yrs ago, it has always been a bad ignitor,. Good Luck, Appliance Specialists
1helpful
GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
1helpful
Oven will not fire up fgf354bgwc
Hi, The ignitor could still be bad even if it glows. It is a very common problem on the gas reanges. The ignitor is getting so weak it will not open the gas valve.
I hope this helps you understand what is happening. Please let me know if I can assist you further.
Thanks
Vic
Jul 26, 2009 • Ovens
3answers
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Top Char-Broil Grilling Experts
Paul Carew
vince
ADMIN Andrew
ADMIN Andrew
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
