SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
SOURCE: How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register?
In that case you would select that option and select to deregister the
handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Registering a Handset
If you see a "not registered" message on a handset, you must register it to a base before using it.
1. On the base, open the menu and select "Register Handset"
2. On the handset, press and hold POUND (#) until the handset display says "Handset Registering" (about 2 seconds).
3. Wait until the handset display says "Registration Complete" (about 30 seconds), then pick up the handset and press eND/CleaR.
# If you don't hear a dial tone or the display says "Registration Failed" charge the battery completely, then try again.
