SOURCE: I have a Lexmark All-in-one X5490. Color Cartridge replacement request
Printable Version
How to Clear the Memory on the Lexmark X4250 / X4270
PERSONALIZE FAX: Press Select.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
ENTER TIME: Using the format hh:mm, press Select.
Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
SOURCE: document color differs from screen color- lexmark z617
Sounds like the print head is clogged. Some models have the head in the cartridge, others don't. Those that do, a cartridge replacement will help, others need cleaning manually. Also, a software head cleaning may be all it needs.
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When the printer turns on, reconnect your printer to your computer. Check if problem continues.
