SOURCE: iriver H10 20GB - i can't access my music through Artists or Albums
Have you tired doing a "Database Refresh". It's located on the main screen under "Settings". Go to Database Refresh and check "Yes". How much music you have on your player will determine how long the refresh will take. If that doesn't work possibly run the Firmware Updater from iRivers' web site and only update the database, do not do a complete "Recovery" or all of your music will be erased as that choice reformats your hard drive. Only choose "Update Firmware"
Regards,
John H.
SOURCE: Wrong song titles
Use the proprietary program or re-format within Windows Media Player itself.
SOURCE: Philips GoGear 8GB wont show song titles or artists.
the phillips go gear mp3 player is a total pice of **** the best thing you could do is go out return it and buy a sandisk sansa other wise called a sansa fuse they are great and they have an expandable micro sd card port.
oh and to fix your phlips go gear mp3 player you need to take a pin and stick it in a small hole on the side i belive it is on the left side next to the mic.
SOURCE: hdd6330 claims "empty list"...it's not
Run a Repair in the Philips Device Manager (note: the HDD6330 is not compatible with Windows Vista or with Windows Media Player 11 - pluggging the device into a computer with either of these installed will ruin the player, even though it may work initially).
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
SOURCE: Iriver E10 Reseting Options
can i suggest you try rockox http://build.rockbox.org/ this will give you more than the regular ole iriver software.
but if you really want to start fresh back up the e10 iriver software, format you e10, re-install iriver software, add your media back (i've done this with my kids ipods also..and it works like new)
good luck............feel free to rate if helpful
