Question about Kodak EasyShare DX7590 Digital Camera
Error code E45 for a DX7590 Easyshare Camera - Kodak EasyShare DX7590 Digital Camera
Posted by rmad52 on
Shane
  • 668 Answers
Error 45 is a lens error.
Solution:
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on. If this does not work then try the compressed air. With a fine tip blow off the gun, and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around a the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.
Secondly give a gentle tap on the sides of the camera and then switch on your camera, you will not get this error message as the internal mechanism which is stuck and causing this problem gets working properly.
Hope this helps.
Shane
Posted on Feb 15, 2011
Kodac EasyShare DX7590 Mainboard
Hello, Check Ebay Item #230915354361 This camera should have same components that you are looking for,Do Not know the cost to ship to Jamaica ?
Hope This Helps
Jul 14, 2012 | Kodak EasyShare DX7590 Digital Camera
Como corregir un errror E45 en una kodak V570
The bad news is that this error means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera.
kodak-easyshare-v570-error-e45-users-guide.
Jul 28, 2011 | Kodak EasyShare V570 Digital Camera
Camera error # E45
Just Google "Kodak E45 Error", apparently its a lens jam problem which you can sometimes cure by 'slapping' the camera on your hand.
http://www.pechorin.com/m/2008/08/18/Kod...
Jul 21, 2011 | Kodak EasyShare V705 Digital Camera
When i swich on it says camera error ''E45 see users guide.
E45 error code indicates the lens of your camera is already defectived. You need to contact Kodak at 1 800 235 6325 ext 12. Your camera needs repair
Feb 03, 2010 | Kodak EasyShare Z700 Digital Camera
Easyshare Z612 with an error code of #e45
Itøs a lends error. There is not much else to do than to send it in for repair or go for a trade up.
OoW repair for this model w. this fault: 88,07 Pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 14, 2009 | Kodak EasyShare One Digital Camera
Error E45
It's a lens fault and the camera needs a repair.
OoW. repair of 88,07 Pounds ex shipping
Contact KODAK:
Oct 26, 2009 | Kodak EasyShare Z740 Digital Camera
E45 Error
turn the camera off and then on. if you encounter the same error, go to www.kodak.com/go/itg to either avail of the service upgrade program or get it repaired.
Apr 11, 2009 | Kodak EasyShare LS753 Digital Camera
Camera error # e45
http://www.digitalcamera-hq.com/digital-cameras/kodak-easyshare-ls443_question.html?qid=5943
Try your luck
I bought one yesterday new for 25 $, so ...............
Bit more plastic then the previous Kodak but 10+ megapixel and video and moving shot ok.
Rate me for a good advice
Nov 19, 2008 | Kodak EasyShare V530 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
