Question about Texas Instruments TI-84 Plus Calculator
For my ti-84 I try to graph & it says ERR:window range...but when i try to fix the range it won't allow it...is there a good widow range to have for all graphing purposes?
Posted by nperic on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
There is no one good window range for all graphs, since graphs can have different areas of interest.
Press the ZOOM key, then select ZStandard. This will restore the window settings to the default range, which will at least allow the graph to be displayed. You can then change the window range and/or zoom as desired.
If this doesn't do it, please reply to this post, giving the function(s) you're trying to graph and your current window settings.
Posted on Feb 15, 2011
What is ERR: Domain on thr TI 84 graphing calculator?
The arccosine function is defined for arguments in the range -1 to +1. -125.85/-120.36 is larger than 1 and hence outside the domain of the arccosine function.
Dec 03, 2013 | Texas Instruments TI-84 Plus Calculator
ERR WINDOW RANGE
This is a problem with next resolve options:
Mar 13, 2013 | Texas Instruments TI-84 Plus Calculator
It wont let me graph. i keep getting an error message err: window range.
You need to press the "window" button located at the top of the calculator, then change the Xmin,Xmax,Ymin, and Ymax to values that your graph will fit in.
Apr 28, 2011 | Texas Instruments TI-84 Plus Calculator
When I try and graph on my TI-84, "ERR: INVALID
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 09, 2010 | Texas Instruments TI-84 Plus Calculator
Whenever I try to graph on my calculator is says "ERR: WINDOW RANGE" no matter what I type in.
Press ZOOM 6 to reset the window range to their defaults. If that doesn't do it, please reply to this post specifying the exact function you're trying to graph and your window settings.
Nov 03, 2010 | Texas Instruments TI-84 Plus Calculator
I have the TI-84 Plus calculator and when i try to graph anything, it says ERR: WINDOW RANGE. What do i do?
Press WINDOW (the second key on the row of function keys at the top of the keyboard) and check your settings. Alternatively, if you're plotting a function press ZOOM 6 to set the standard window range and if you're plotting data press ZOOM 9 to set the range to go with the data.
Oct 19, 2010 | Texas Instruments TI-84 Plus Calculator
Calculator all of a sudden stop graphing. When i hit graph it says err:window range
Press the WINDOW button (2nd from the left, very top row) and check the window limits. In particular, make sure that Xmin and Ymin are less than Xmax and Ymax respectively.
If that's not the problem, append a comment to this post listing the window variables and the function you're trying to plot.
Jun 24, 2010 | Texas Instruments TI-84 Plus Calculator
I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Aug 13, 2009 | Texas Instruments TI-83 Plus Silver...
My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
"Err: Data Type" - Not Allowing Me to Graph
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Jul 25, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
443 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
