Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
My dehumidifier is running but no water is collecting and the bucket usually fills in a few hours, what can be the trouble I cleaned the screen.
Posted by julylady62 on
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 07, 2011
My dehumidifier run but it does not collect any water?? I have unplug it a few minutes and clean the air flitrer still the same result HELP Please
heatman101
Jul 07, 2011 | Fedders A3DH30B2A Dehumidifier
The fan is operating properly but it is not pulling enough moisture out of the air. For a year now it has filled the container in about8 hours but now only about one inch of water. Is there a screen or...
heatman101
Jun 25, 2011 | Kenmore Dehumidifiers
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
My DD50E has stopped collecting water and filling up. It runs but doesn't collect water.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 17, 2011 | DeLonghi DDE50E Dehumidifier
The dehumidifier will run, but will not collect any moisture from the air. The screen has been cleaned, the tub is cleaned, but no water will collect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 07, 2010 | Haier HD456 Dehumidifier
Sometimes the machine will run and sometimes it will do nothing when it is turned on. When it does run there is never any water collected in the bucket. I have let it run for as long as 12 hours and still...
heatman101
Aug 25, 2010 | Haier 45-Pint Dehumidifier
Nno much water generated
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
Take care.
Aug 01, 2010 | LG LHD45EL Dehumidifier
Dehumidifier runs but collects no water - coils are clean there is no obstruction the humidifier worked until a few weeks ago
heatman101
Jun 17, 2010 | Goldstar DH504EL Dehumidifier
It is not collecting water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 18, 2010 | Fedders R6DH45X Dehumidifier
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Sep 17, 2008 | Dehumidifiers
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
551 people viewed this question
Top Whirlpool Dehumidifiers Experts
Marvin
Marvin
Mike
Tim Venetis
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
