Question about Toshiba Satellite Pro S300-EZ2501 Laptops
Where can i get Satellite Pro S300-EZ2501 motherboard to buy
Posted by liquid90gh on
  • liquid90gh Feb 15, 2011
    hi thanks but can i get a different shop to compare prices thanks
Computer Links
  • Toshiba Master
  • 2,386 Answers
Hello
You can get the motherboard from your nearest Toshiba Service Center or you can buy online from HERE
Good Luck
Posted on Feb 15, 2011
I need to unlock my toshiba satellite pro s300 password because i forgot it
If it is the hard drive/system password, there is nothing you can do except copy your data with another PC, re formatting the drive and reinstalling all of your programmes. Then you can put your data back in.
Jan 26, 2013 | Toshiba Satellite Pro S300-EZ2502 (4400...
The touchbad and the mouss can not responding completly
your best bet is to backup your data, reinstall the windows from the factory settings. if that does not fix the issue, the touchpad needs to be replaced
May 03, 2011 | Toshiba Satellite Pro S300-EZ2501 Laptops
My granddaughter pushed the F2 button while the start screen was on. how do i get out of this i keeps saying media test failure exiting PXE ROM
The F2 function on this laptop merely cycles the power plans (see link below)
http://static.compusa.com/pdf/Toshiba-Satellite-Pro-S300-Laptop-Manual.pdf
The symptom you describe is that of the OS or a boot device not being recognised. Try removing any USB dongles from the laptop if any are plugged in, eject any CDs in the tray and retry
If this does not work, as the laptop starts up, press the ( I think) F1 key and enter the Bios, see if in the BOOT screen, the hard drive and CDRom are shown. Repost your findings for more guidance
Dec 28, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
I have installed windows XP on my toshiba L300 and now webcom shows error every time i start.
I have found driver for the S300, I couldn't find L300 drivers anywhere. Try the "Toshiba-Satellite-Pro-S300-Webcam-Driver-For-XP" here:
http://www.general-search.com/fileinfo/4691363
Dec 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro S300-EZ2501 Laptops Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
