Computers & Internet Logo
Posted on Feb 15, 2011
Write protect erroe give cant not format and copy files in my 8g DT101 data travel plz help me
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
553
Points
Write protect error give cannot format and copy files in my 4g DT101 data travel plz help me
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
1helpful
Please insert disk into removable disk
have you tried other a different flash drive of something like a usb charger etc? If it works then then the problem is with the flash drive, if not them its with your USB port
1helpful
Kingston Technologies 4GBG DT101 DataTraveler write protect erroe give cant not format and copy files in my 4g DT101 data travel plz help me
what you need to do is connect your usb drive, then open a command prompt window (Programs->accesories) and in this window type:
diskpart.exe
and press enter
you will be presented with another window similar to the first. In this new window type:
list volume
and press enter
this will show you a list of all drives connected to your machine.
Next type:
select volume *
where * is the volume number of the required drive listed in the list volume section.
and press enter
This will select the drive for the change you are about to make.
type:
detail volume
and press enter
this will list all of the attributes to do with the selected drive, you should see in there that the disk is write protected.
next type:
ATTRIBUTES DISK CLEAR READONLY
and press enter. Once the window has finished what it's doing you can close all of the command prompt windows and your disk should be ready to use again.
Hope this wasn't too long winded and has been of some use to you.
1helpful
I own a Data traveler Kingston DT101 8GB. My files are broken in folder FOUND.000. I also tried to scan it with anti virus and error checking but still nothing happened. Files are named: FILE0001.CHK...
Those files are nothing but lost clusters recovered. If the data is very important for you, there is a chance to get it recovered, however, it won't be free. You can contact any local vendor or try the following link.
http://www.data-recovery-usb-drive.com/
regards
Sandeep
2helpful
I bought Kingston dt101/16GB and can't copy large files into it. it begins the copy but hangs up. I have anothers dt101/8GB and they work fine
1. If it is formatted into FAT32, it will NOT copy files larger than 2GB. If you have larger files, you should format the drive in NTFS.
2. It may be a fake drive. You can use h2testw software to check if it is of fake capacity.
1helpful
HOW TO REMOVE WRITE PRTECTED OR AUTORUN.INF FILES
removing write protection in pen drives is impossible..because tht is due to some hardware problemsi and no software can remove writ protection..anyway try this..logon to a linux machine(i prefer ubuntu )
and in terminal route to your drive and type sudo chmod-R 777/media/ and press enter..if one failes to delete files again..then throw away the pendrive.he heh..!!
84helpful
10answers
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
43helpful
6answers
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 • Nokia 3230
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
