Question about Activision Video Game Consoles & Games
WHY WONT MY PS3 READ A DISC IT MAKES A WEIRD SOUND WEN I INSERT I TRIED THE RESET THING AND DID IT WORK NO ANY HELP
  • Adam Powell
    Adam Powell Feb 15, 2011
    Would you describe the sound as a scratching disc (like when you pop open the lid on a cd player) or like loud *pops* or does it make a certain tron-like futuristic sound?
Kevin Penn
  • 1,139 Answers
This is because of an internal gear fault within your PS3. It is possible that someone has taken the PS3 apart before and not put the drive ack properly or there is a possibility that one of the gears inside has broken. You could have a look yourself by following a guide on youtube, just google PS3 blu ray videos. At the very worst you would have to buy a new mechanism for your PS3 blu ray.
This is not actually that hard as all you would need to do is buy a faulty blu ray drive (one where the laser is faulty) and swap over your working laser into it. This would cure your problem. The only thing you have to be careful of is that you get the same model blu ray player as there are several types. To identify the right one you need your model number of your PS3, it is on a white sticker on the back and starts CECH--.
This will be your cheapest option for repairing it unless it is under warranty, Sony have a 1 year warranty with new consoles and will replace it free of charge if it is still in warranty. If it is out of warranty Sony will want around £150 to fix it.
I hope this information helps and thank you for using FixYa
Posted on Feb 15, 2011
Put a game disc into ps3 grinding noise wont show game icon
Make sure that you do not have the PS3 on it's side. Lay it flat. Insert a MOVIE DVD first and see if it will recognize the disc.
If you continue to hear a grinding sound when the ps3 is laying down that could only mean one thing, you need a replacement drive.
Dont forget to Always update your Playstation to the newest firmware.
Dec 24, 2013 | Sony Playstation 3 (PS3) Console
Ps3 loads most games first time however after about 20 mins of playing battlefield BC 2 the sound stops working i can hear people talk through headset but no game sounds when i reset and insert the game...
Hi Danny41,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
Apr 27, 2011 | Sony Playstation 3 (PS3) Console
I bought god of war 3 for my ps3 and when i insert it it sounds like its gonna read and then it makes a clank noise and nothing happens but it reads all other games but this one
It sounds like the disc is broken. Blu-ray disks are scratch resistant, but if they have even the tiniest of cracks or dings, the disc is often unplayable. It is usually characterized by the weird sounds you're hearing when you try to load the game.
Take the disc into bright light and check the underside very carefully, looking for any sign of a hairline crack. Even if you can't find a crack, my suggestion is to return it for a different disc, as it seems probable that the game is broken.
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
Ps3 not reading disc..Please help
Do you see the little clock like icon in the top right corner of the screen when you first insert a disc the loading disc icon? if so then it could either just be the drive itself or a software issue in which case you can try a few things before replaceing the drive.
First just reset to factory default settings under system settings.
P.S. i assume its not reading any kind of disc if it isnt reading anything also double check to make sure the disc you are using are still good and not just really dirty or scratched. GIve us more info and what disc your trying to check so we can further help you out.
Justin
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
When i updated my PS3 for the new Call of Duty it stopped reading the disks. It worked fine b4 the upload but now it wont play any of d games i have. Whats d craic, how do i sort this
It might just be coincidence that your blu-ray drive has packed up at the same time as the update. Ring up Sony and tell them this and you could get a new console for free if your in the warranty.
Nov 12, 2009 | Sony Playstation 3 (PS3) Console
Can't play games or movies
you have a disc read error on your ps3. you can either send it to sony and pay 150 if not under warrenty, or you can get a whole new disc drive for about 50-60 bucks on ebay. you can find a video on youtube on how to install it yourself. its pretty simple.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
May 29, 2009 | Sony Playstation 3 (PS3) Console
PS 3 rejecting disc
try holding down the reject button for more than 10 seconds to reset it. if that doesn't work phone sony as all ps3s are supplied with a 1 year warranty
Dec 23, 2007 | Sony Playstation 3 (PS3) Console
Xbox 360 will not read disc and is making a weird noise
Is it doing this while the disc is in the drive? Also does it sound like a loud rattling sound?
Oct 13, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
267 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
