I have a philips plasma model 42pf9531/98 it's main power supply circuit panel is broken so i want to buy a new one pls help me fom where i can buy that part? e.mail me [email protected] thanks
SOURCE: PLASMA PHILIPS MODEL NO 42PF7320/98
You need to post the part number off the board. Most of them are 310432842631 for the A/37. Best found on eBay.
SOURCE: Power cannot start red led blinking
Check the power board for caps with the tops bulged up. 3300uf 10v.
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
SOURCE: 42" philips plasma, black screen and flashing red light
I did the same, replaced two bulging capacitors...cost me 2.00 for the capacitors and $20 for the desoldering/soldering tools. First time doing anything close to this with any electronics...tv works great now.
