Sony BDPS570 Bluray 3D Player Logo
Anonymous Posted on Feb 15, 2011
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
Electro Med Services
Level 3:
  • Sony Master 6,694 Answers
  • Posted on Feb 15, 2011
Sony Master
Level 3:
Answers
6694
Questions
Helped
1870107
Points
21433
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
  • Anonymous Mar 10, 2011
    You may also hold down the stop button from the player itself (not the remote) so it will lower the output resolution to SD. This way, you'll get a picture on screen and you'll be able to set the correct resolution on your TV according to its specifications.
How to connect new flat screen tv with hdmi cable to an olin ross sound system 6050 home theater 1000 watts
Evidently this system is a speaker system that hooks up to 5.1 home theater receiver. I've included a few quote on how to hook up the 6050 system:
" Measure and cut wires running from the speakers to the receivers"
Read more: http://www.ehow.com/how_10058195_hook-up-olin-ross-or6050.html#ixzz33bqoGyyY
"Run the wires from all speakers and the subwoofer to the back of the receiver".. The key is to have a home theater receiver, then you can hook up the TV to the receiver.
5answers
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
How to hook up my cable box and tv to panasonic sc-btt190
You could have a bad Hdmi outlet . Try hooking up component c what happens
When hooking up HDMI why can I not get sound I hooked the HDMI from the cable box to the reciver and from the reciver to the TV I assinged the Hdmi and I get picture on the Tv I also can get sound out of...
I have researched on your issue and found that the Receiver is not capable of processing audio from HDMI input. It will bypass the signals from its HDMI input to HDMI output..
The Receiver has 3 HDMI input and one output. Hence you can use this as a HDMI switch to connect three HDMI devices to single HDMI port on the TV.
In order to get the sound from speakers connected to the Receiver, it is required to make alternate digital or analog audio connection.
You can confirm the information from the manual of the Home Theater System. Please refer page # 36 of the Manual to get the information. I have provided a link where you can download the Manual for the HT System:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/580/580HT5100B.PDF
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Dvd hdmi cable into receiver
unhook and reconnect a few times, try with power on and off, (they have to communicate with each other) if not, return receiver and get a new one.. I had this happen with my yamaha...
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
