Garden Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a diagram for a peerless transaxle 855 Series
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
  • Posted on Feb 15, 2011
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171739
Points
784
The Peerless brand is going through some changes. Here is the current info on the company.
http://www.peerlessgear.com/files/Peerless/splashimage_full3.jpg
2answers
How do I install seal in the transaxle?
Require splitting the case if your trying to replace axle seals. Case is sealed with Permatex Ultra Grey sealant
Http://www.recrepairinfo.com/product_info.php/tecumseh-peerless-transaxle-920-series-repair-manual-p-6176
are you talking about driving forward? that doesnt sound quite right. there is a reverse safety switch and paddle that are meant to do that exact thing but in reverse. Mine has a key position back one from where you release after start. when you move key to that position, i can go in reverse with the deck still engaged.
Peerless tecumseh transmission model mst-206-545c will not drive in gear
FYI I have a Craftsman LT1000 18HP twin opposed Briggs with a Peerless transaxle 206-545c 6 speed manual trans (not the Hydrostatic). I was given this Lawn tractor by a friend who took real good care of it. runs starts great but it started binding in 3rd gear and was very hard to get it out.of gear so by pushing the cluch/brake in and out manytimes and forcing forward into 4,5,6 gears I was able to get it out of 3rd.
Iam a mechanic and have over 30 years experience.so I decided to research the Peerless 206-545c transmission I found some great info online and helpful repair vids on youtube. I decided to post here to try and help people that are having the same issue with this trans. after I got the tractor in the garage I noticed the left rear wheel was wet on the inside with gear oil.so I decided to do a rebuild.after learning about this transmission.I went to sears parts direct.com and put in my craftsman mower model number and it came up with a exploded view of the tecumseh\peerless 206-545c. on the diagram. I found the 2 transaxle seals needed item# 157 and for like 15 bucks ordered them. you can order all the seals if you choose.
I realized that there is a fill PLUG ONLY and no drain plug on the bottom of transmission.you must take this transmission out of the tractor and lay it upside down in a oil catch pan and drain the fluid out. you must open the transmission all the way to replace the transaxle seals.Im told that most lawn tractors of today have disposable transmissions.another words they dont want you to fix them youreself they want you to bring it in so they can charge you to diagnose it and say yep you need a new transmission. lol thats why no drain plug.so if youre not a mechanic you gonna be payin boy..
I did find alot of BAD info in doing research on this transmission online ie: people posted wrong info saying that you just have to loosen all bolts on the trans case and you can put new seals in... VERY WRONG and the other wrong info was the amount of gear oil. the correct amount of 80w90w is 32oz 2/3 full from top(use a dowl or straw to measure. I use LUCAS high Performance. gear oil. I included a Tecumseh/Peerless link for you to check out. http://www.smallenginesuppliers.com/html/engine- specs/tecumseh/Tecumseh_Transaxle_Service_Information.pdf scroll down to MST 200 series trans find the 206 545c documentation and it tells you every thing you need to know about the 206-545c ie 90/100 inch pounds when torqing bolts on case. shifting adjustment (ball hex screw adjustment) 1 full turn after flush with housing.etc. I was able to save this transmission I opened it up and cleaned every gear by hand with Seafoam trans cleaner and put it all back together using permatex (GEAR OIL GASKET MAKER) and waa laa it shifts amazing and no more leaking from axle seal. I get no benefit from posting this just want other people to have the correct info and for around 40 bucks you can recondition this trans.if you open it up and find broken gear or gears go to ebay or sears and get parts which ever fits your buget.it took about 6 hours total to de install transmission and clean gears and put new seals and re install back into the tractor. just to give you a time frame. if you dont have time to rebuild it go to ebay there are used complete transmissions there but I would rather know what I have by doing it myself than buying used that may have the same issue and cost ya 200 bucks.
god speed bruthas
Aug 12, 2013 • Garden
How do I add oil to my sears garden tractors transaxle model no. 917.273320
I'am not sure about this model. Craftsman,usually services the Transaxle at the factory. Requiring no further servicing,unless you have a leak developing,then an overhaul of the transaxle has to be made.I would get a professional in a mower shop,to make this repair. Or Sears does this sort of work. I have seen this Transaxle,(A Peerless Transaxle),torn down for repairs. There is more small parts to this transaxle,then anyone other than a Sears Tech or someone trained to do this. Its more work,than a weekend doer can possible do. Hope this is answers your question,Brad Locke DTD. 12/03/15
Leaking rear axle seal
If has a Peerless transaxle you need a oil seal 780088A. Its where axle comes out housing. Just pry it out and replaced.
2answers
Peerless Transaxle #206-545c locked up in 3rd gear, wheels won't
Sounds like your going to have to open up the tranny....
2helpful
2answers
Change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Top Garden Experts
Jay Finke
Jay Finke
john h
