Question about Bosch Axxis WFL 2060 Front Load Washer
When I choose a temperature and setting, as well as a wash selection, and then push the "START" button, nothing happens. The "door locked" light turns red and the "wash" light turns red, and there is a hum... but no water.
Posted by mary_s_armst on
Dwayne Hoo-Fong
  • 403 Answers
Does it also sound like the board is clicking? Your drain pump is bad. The control board is sending power to the drain pump, but the power is not being returned back to the control board to complete the circuit. I actually just diagnose this same exact machine about a week ago. lets just say it took me a while to figure it out.
Remove the cover at the bottom right of the dryer covering drain pump access area. Remove the hex head screw, and slide the bottom panel to the right and remove panel. Disconnect the power going to the drain pump. Turn the washing machine on, Should do the same thing you described above. Using a multimeter, check the power in the plug that you disconnected from the drain pump. Should read 120v. I' betting it will.
St your multimeter to check for resistance or better yet continuity. Touch each lead to the 2 pins on the drain pump. If there is no continuity or no resistance reading, then the drain pump is bad and needs to be changed. Once changed, your washing machine will run like new again.
keep me posted.
Posted on Feb 15, 2011
Start button does not activate door lock and will not turn on
It may be a micro switch that is not engaging. Try pushing on the door to see if that solves the problem. If so, put in a spacer to push the switch more.
Jan 24, 2015 | Bosch Nexxt300 WFMC220 Front Load Washer
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Maytag epic Z He washer ecu reset
Unplug it from the wall for 5 min's to reset.
May 05, 2017 | Washing Machines
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
