You can try checking out amazon.com or landofnod.com for the crib mattress that you need. Make sure you know the dimensions of the bassinet you are looking for. You can find the features and the description when buying.
Also check Eddie Bauer list of products to find out if they offer spare bassinet mattresses for their cribs.
Source: http://www.bestmattressreviews.com
SOURCE: lowering crib mattress
What is the exact make/model of the crib? Did you just purchase it and put it together?
Thanks,
Lee
SOURCE: cosco crib assembly
have a crib that was given to me so dont have instructions
Cosco Sleigh Crib
Model # 90242
please help!!
SOURCE: the mattress brackets
I was pretty disappointed when I encountered this problem and got
excited when I found this site and thought my problems were over.
However I was even more disappointed to have people on here say how
they called customer service
and they were sent instructions and pictures and it worked perfectly,
yet they failed to share any of it. I personally think the idea of
switching the brackets around contrary to the instructions is a bad
idea. The notch on the round hole end secures into the pole to keep it
secure, switching it around will make it unsecure in my opionion and I
think it would damage the wood as well.
I tried to call the
company, however it was Friday night when I started and can't in good
faith leave it uncompleted till they open on Monday. I was tempted to
just go out and find 2 wooden blocks that would cover the gap, I still
think that would work, however I didn't do it. Here is what I did.
I
just loosely put all 4 screws in, then tightened the rear brackets into
the wood first, then just went ahead and screwed in the front ones. The
brackets had to bend a bit to cover the gap, but they don't seem to be
under too much stress. In the end it seems pretty secure to me. I do
plan on calling the company when they open on monday, and if they give
me some simple fix I will be sure to come on here and share with the
rest of you.
SOURCE: corner cribs
I am selling my whole set, the crib, mattress and bedding on ebay! Loved it, but do not need it anymore. It will be posted there in the next few hours. Just type in Corner Crib Nautical into the search. Local Pick up only.
Or contact me [email protected]
SOURCE: How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
