Question about Nikon D60 Digital Camera
I just purchased my d60 camera, unfortunately I bought it on craigslist, it came with a nikkor 50mm lense, I wanted a auto focus lense to take some sports pictures, I took it to shutterbug camera shop and was told the camera is broke, it would not except the lense they put on it, it would not focus. I understand that this model does not have a auto focus motor in it, but I was under the understanding I could purchase a lense that would allow me to have auto focus capability? I was told I need to find out if my camera is a "as" or a "af" Im not sure where to find this information, it just says D60 on the front. Serial #3490708
Posted by sktc88a96 on
Robert Taylor
  • 747 Answers
That's odd that Shutterbug camera shop couldn't tell you everything you needed to know about that camera. I looked it up in a PDF manual because the new "small frame" cameras require different lenses as is the case here Autofocus with this camera is only supported by AF-S and AF-I lenses the lens is equipped with the autofocus motor other types of lenses will not autofocus.
The "kit" lens for this camera is the AF-S DX Zoom Nikkor 18-55 F3.5/5.6G VR.
Now if Shutterbug camera shop mounted an AF-S lens and the camera didn't autofocus then they are right in saying it's broke. I just find it strange they couldn't tell you that straight up. You need to install an AF-S lens and try it, again they may have put the wrong type on it and of course it won't work.
I take it that you don't have the camera manual?
If not go into Google search Type in Nikon D60 PDF manual and click search fifth one down on the first page is what you need click on it and download your "new" manual
Here is the link I used
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=Nikon+D60+Digital+PDF+manual&cp=28&pf=p&sclient=psy&aq=f&aqi=&aql=&oq=Nikon+D60+Digital+PDF+manual&pbx=1&fp=64f84e119f52b91a
See if that helps, personally I think you just need the correct lens.
Posted on Feb 15, 2011
Why does my Nikon D60 while on auto focus or quick shutter speed either not focus and take the pic or focus and not take pics?
I have a 5D Mark II that has acted up like this. 99% of the time it will reset itself it you power off, remove the lense and allow them to sync up. Try this, it may work for you too!
Apr 22, 2012 | Nikon D60 Digital Camera with 18-55mm lens
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
I got this lens (Nikon AF NIKKOR 50mm f/1.4D) for my D3100 and it doesn't autofocus. I don't knowhow to intervene since there's no switch on the lens itself (because I understand it is small and it doesn't...
The D3100 can't autofocus with this lens. The D3100 does not have a focus motor, depending on the lens to have one. The AF-Nikkor 50mm doesn't have a focus motor, depending on the camera to have one.
To autofocus, you need lenses designated AF-S.
Dec 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I locked my nikon 50mm lens aperature ring to the appropriate setting for my Nikon D60, yet the camera still tells me to lock it into place, as if it is not registering the fact that I've locked it down...
Sounds like the coupling pin on the body is missing, Try a diff auto focus on the body, If it still does it then I believe that\'s the problem, On the body next to the lens mount, About 7 o clock there should be a lever that couples with the lens when is is at f22 or larger
May 13, 2010 | Nikon 50mm f/1.8 AF Nikkor Lens
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D60 Digital Camera Logo
270 people viewed this question
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
