Question about Denon AVR-1801 Receiver
Mi Ipod was playing thru the VCR 2 output via an rca>1/8 inch jack. No longer get any sound from that or the VCR 1 output. Phono output gives sound with an overloaded bass. Is the receiver shot? Thanks.
Posted by rmorgan388 on
David Dunn
  • 8,546 Answers
PHONO is ONLY FOR A TURNTABLE.
You don't say if the iPod still works with any other Line level >>>> INPUT <<<<. There are 8 of them.
Do you have any other devices to test the VCR1 and -2?
Posted on Feb 14, 2011
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_195f36f311cb10df
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
How do i get my TV to play thru the surround sound of the unit ?
If your TV has a headphone mini jack output ....you need a mini jack to double phono lead ....ask at any decent tech shop.
May 11, 2014 | Insignia IS-DVD040924 DVD Player/VCR
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
I want to connect an iPod to my Marantz SR 5600, what type of cord do I need?
You need a jack-2cinch (differen name is jack to 2 RCA) cable. Jack goes to your iPod's phones output, cinch/RCA to amplifier (connect it to CD or DVD analog section at the back). While playing set volume to 50% to avoid distorted sound. This way you can connect any MP3 player to your amplifier.
May 08, 2011 | Marantz Audio Players & Recorders
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
Can connect a ipod to pld2000
yes you can connect it
http://www.eseelectronics.com/html/pld2000sec.html#
does the back look like this?
if so then go to ebay or any other electronics shop and buy a ipod cable
3.5mm jack >>>>>> phono jack (red, white)
with this connect the phono jacks to the audio in, in AUX 1 and select AUX 1 on the system and plug in your ipod to the 3.5mm jack and play
May 10, 2010 | Teac PLD2000 System
How to play my ipod through this stereo
USER GUIDE
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
Can i listen to my ipod threw the theater sound system
your home theater has a AUX phono plug in the back
you need to buy or make a cable that looks like this
to buy
3.5mm headphone jack>>>>> phonojack
if that cable has only one phono jack on the other side then you also need this
one phonojack>>>>>two phono jacks
this is needed because if you kept it as one jack then only one side will play music
if you make it then
3.5mm headphone jack>>>>>> two phono jacks
Jan 11, 2010 | Panasonic SC-HT520 System
Denon AVR-1801 Receiver Logo
Top Denon Audio Players & Recorders Experts
tina gallow
midland10
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
