Question about Kitchen Ranges
I have a dayton 5k565ag 1 1/2 motor I want to wire for 220 volt. what wires do I connect to my power source? Coming out of the motor are 2 single wires, 2 wires that are connected together with a wire nut, and 3 wires connected together with a wire nut. I am picking major appliances because you are the closest in relation to my question.
Posted by rizzifamily on
5 Related Answers
Anonymous
  • 1073 Answers
SOURCE: how to connect a 220 stove with 2 110 cables
cannot be done you would be using the same side of the line and it would be a direct short
Posted on Apr 27, 2008
Anonymous
SOURCE: Kelvinator Stove Power Cable Connection
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Richard
Posted on Nov 23, 2008
Anonymous
  • 71 Answers
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Posted on Jan 13, 2009
Anonymous
SOURCE: I have a 220/440 v single phase 2.2Kw ac motor driving the
Read the 'How To' Blog on www.inverterdrive.com - this should help you.
Posted on May 20, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: i need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 21, 2009
I have a Dayton Pahse 1, 3/4 HP motor that shows 115/230 volts on the label. I just had an outlet coverted to 240. I plugged it in and the motor barely moves and sounds like it is stuck or not enough...
there should be a diagram on the label for 110 or 220v-are you sure the last garage you ran it in was 220-it should only run at one of those levels without re-wiring the motor-cheers Denny
Oct 29, 2013 | Dayton Permanent Split Capacitor Motor Fan
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 21, 2013 | Pool & Spa
How towire a 220/110 7 wire single phase motor to 2 wire plus ground switch
This is very simple, but you need to make sure you have the correct wires in hand. If you are wiring a 220/110 motor, and you are wiring it for 110 use, you will only be using 3 wires. If this motor has 7 wires, most you will need to cap off.All you need to use are P-1/Line 1 is your 110 hot. Cap off T-4, 2, and 5, Line 2. That would be used for 220 volts. P- 1 will go to your hot wire on press. On the new motor, T-8, P-2, and t-3 you say are insulated? You will need a Neutral wire to tie to the other line wire coming from the press. And the 3rd wire will be your ground. So, P-1 is hot to your press wiring, t-4,2, and 5 capped off. T-8, P-2, and T-3 has to be a Neutral wire, I would think that if T-4,2,and 5 are line -2, this would be for 220 volts. You are being confused by so many wires. You will only need to use P-1 power for 110 to press power wire, find which wires are Neutral and a ground that will go to your press wiring.P-1 will go to Red if this is hot to the press, Black to Neutral, and on the new motor you will see what color is ground, normally green or bare copper. 3 wires only. You will only need the p-1 hot, a neutral, normally white but may be black on the new motor, and a ground. Look at the Diagram on the new motor, and it will tell you the combination. P-1, Neutral, ground, and cap off the other 4 wires. I hope I havent confused you more, it is very simple, its just the colors of the wires the are confusing you and the amount. Just remember, you only need to use 3 of the, P-1, Neutral, and a ground.
Shastalaker7
Apr 06, 2012 | Heating & Cooling
Recemtly my pool sweep motor burned out so i had it rebuilt. I had to un wire the sweep side of the dual intermatic timer and when i tried to re ook it does not turn on. i was sure i unwired the two...
Hi Tom - I located a source for you to download a copy of the manual for this timer, here. This timer has several variations - which can not be determined with 100% certainty by me from the info you provided in your question, but I believe your application is the large, bottom schematic called "Filter and Cleaner Timer Inter-connections".
If a 240 volt circuit, both the power source and motor load should consist of 2 hot wires and a single bare, green or green & yellow striped ground wire. The 240 power source wires connect to terminals 1 & 3 and the 240 volt sweeper motor would connect to terminals 2 & 4. It does not matter which of the supply wires connects to terminal 1 or 3 - nor does it matter which motor's wires connects to 2 or 4. It is not possibly to change the direction that the motor turns by swapping wires in the timer. The green (ground) wires must all be connected together.
I hope this was helpful & good luck!
Nov 28, 2011 | Intermatic T10404R - Two 220 time clocks...
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Help with Thermostat Wire Connection
White from power source to white of fan. Black from power source to black (top of thermostat). Black (bottom of thermostat) to black of fan..... 120v. connections.....gs
May 18, 2009 | Electrical Supplies
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
ADMIN Canada
ADMIN Canada
Are you a Kitchen Range Expert? Answer questions, earn points and help others
