Question about Apple iPhone 4 Black Smartphone
I cannot get any sound through headphones or internal speaker on my iphone 4 using apple remote which is paired with my home laptop windows 7 and my iphone .everything works ok except no sound when i play a music track through my iphone 4
Posted by kquinn669 on
Anonymous
    New Friend:
    Problem Solver:
  • 12 Answers
Using the apple remote app on the iPhone only changes the song on your home laptop with windows 7. To play songs through your headphones or internal speaker you have to use the iPod app that was preinstalled on your iPhone 4.
Posted on May 04, 2011
1helpful
2answers
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
1helpful
2answers
I read that Apple removed the headphone jack, so how do I listen to music, videos, and podcasts on my iPhone 7 Plus?
blu tooth or they said something about using charging point but will need new ear phones. News said $150 approx
Acer iconia tablet problem
Few things.
If you are talking about the built in speakers, make sure your volume is turned up. And make sure its turned up when the headphones are not plugged in. My android tablet has individual sound profiles so while I might have the sound muted when the headphones are not plugged in, if I plug them in, the volume jumps to my set level because that's where I turned the volume up to last time the headphones were plugged in. I've also had two tablets that the speakers went out completely on that to is a possibility but if you are talking about the built in speakers, check the volume levels first. You can get to them in the settings menu. Its worth noting that plugging anything into the headphone jack will "turn off" the internal speakers altogether.
If you are talking about external, plug into the jack speakers, on a tablet, you're going to need a set of powered speakers as that jack is not going to produce enough power to drive an un-amplified speaker. Make sure you are using a pair of speaks that plug into the wall such as PC speakers.
Second, if you are using powered speakers and still not getting any where, look at the jack end of your head phones and compare it to the jack end of your speakers. I know iPhones and other Apple devices have an extra connect which is why the Apple head phones all have an extra ring. My older headphones are worthless in my iPhone because they lack said extra connection. It's possible your tablet also requires the newer connection and the headphones have that while your speakers don't.
Broad answers, but I couldn't tell exactly what we were looking at based on the questions. Hope it helps, and good luck!
2answers
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
2answers
No sound device in macbook air
Apple menu (top left) System Preferences > Sound > Output tab select the Internal Speakers
check your output volume and make sure the Mute checkbox is unchecked.
Plugin a pair of headphones. If you still have no sound. The sound board needs to be replaced, which is attached to the logic board. Meaning the whole logic board needs to be replaced.
1helpful
2answers
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
2helpful
2answers
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
2answers
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
40helpful
9answers
Sound - internal speakers (MacBook Air)
I have a solution for you all.  This fixed the problem for me.  First, make sure you are all running 10.5.5.  If you are not, run software update from the Apple Menu.  If you are set there, go to Applications --> Utilities --> Disk Utility --> Make sure your Hard Drive is selected on the left hand panel --> MAKE SURE the First Aid tab is selected! --> Click Repair Disk Permissions.  This may take a while, FYI.  As soon as Disk Permissions have been repaired, restart your computer right away.  That fixed the problem at my end.  Good luck everyone!
Apple iPhone 4 Black Smartphone Logo
Top Apple Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Oloyede Monsuru
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
