Question about Epson Stylus 880 InkJet Color Printer
Print head needs to be replaced!! Where can I buy new or used ? Thank you
Posted by devitajr on
Anonymous
    New Friend:
  • 107 Answers
Walmart, Bestbuy, Staples.
Posted on Feb 14, 2011
Cannot print magenta
Most likely the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 05, 2013 | Office Equipment & Supplies
HP 1200 Business Inkjet, dutifully prints BLANK info page from printer button.
Feb 19, 2013 | HP Inkjet 1200dn Printer
Hi I removed the black print head and cyan, but since my SP-540V no longer prints black and cyan, the ink inlet pipes are empty. I think the cirduit is defused. how to reboot the ink circuit. Thank you....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 09, 2011 | Office Equipment & Supplies
HP-4150 pulls paper, but does not print material. Thank You, Opal
Aug 14, 2011 | Office Equipment & Supplies
My Epson NX400 will not print even after I replaced my black ink cartridge twice. Is it possible to fix ? Or, do I need to buy a new printer and what would it cost to repair? Or , how would I repair this...
May 30, 2011 | Epson Stylus NX400 InkJet Printer
The repair shop I took my HP Photsmart 3200 All-in-One to told me the print heads had been destroyed by using refilled ink cartridges from Office Max and that the print heads were NOT replaceable, that I...
The print heads are not replaceable unless you know what you're doing. Even if you did know what you're doing, you need another bad printer of that series to exchange the print heads. It is easier to just buy a new printer that uses the same 02 ink you're used to, especially if you have a CISS system.
Oct 05, 2010 | HP Photosmart 3210 Printer
Do I really need a new print head - or should I buy a new printer?
i believe the printer u are using is a bit old,,the head is worn out and its natural..every hardware equipment has a eol{end of life},,u can print but the quality of the print will deteriorate with time..
i dnt know the model no,, but i think it wont be wise to buy a print head than buy a new printer,,reasons
1.new printers are really chaper than old ones and the price ratio of buying a new printer wud b better than changing the head
2.if even u buy the printer head it is complicated to install it and if correct allignment is not achieved on the plane head then the whole printer is useless
my advice:use the old printer till u get a satisfactory printout,,then buy a new printer
best of luck,,keep me posted,,giva good rating
May 19, 2009 | Office Equipment & Supplies
Epson Stylus 880 InkJet Color Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
