Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung HD501 LJ has a serious clicking problem ocassionally which causes freeze-ups, super slow response, faded white screen etc. When not clicking, the computer runs excellent. I have tried cleaning, switching cables but still it clicks alot. Repace the drive?? Thanx.
Anonymous
Level 3:
Guru:
  • Master 767 Answers
  • Posted on Feb 14, 2011
Anonymous
Master
Level 3:
Guru:
Answers
767
Questions
0
Helped
188204
Points
1958
This is known as the click of death. You can see a full explanation and how to solve it by checking out this YouTube vid.
tip
Fix Hotmail slow and freezing
Any ideas why Hotmail freezes? This is a serious problem for Hotmail users. You can not bear the free e-mail gets slowdown and freezing, so you are looking for a way to solve it? The tips provided by our computer technicians can help you get rid of the problem in minutes. Follow me and read the guide to fix Hotmail slow.
Tips 1
When the problem occurs, you should open the Task Manager and end the frozen page. Many e-mail slow problem due to temporary Internet Files. They are the garbage you never need.
Manual removal Temporary Files and caches
1 Click Tool to drop-down the menu and select Internet Options.
2 Click Settings on the General tab.
3 The Delete File button enables you to remove junk items such like Temporary Internet Files, Cookies History, etc.
Tips 2
DNS is short for Domain Name System. DNS was designed to deal with the IP address you type in. Cleaning it is easy, just visit How to clean up caches and registry.
Hotmail freezing not only caused by junk files but also due to IE browser version incompatible. Check your browser update and download the latest version.
Other causes of Hotmail freezing and slow
If ActiveX controls and plug-in are not enabled, the webpage may hang up. To enables ActiveX controls and plug ins, you should go to Tool > Internet Options > on the Security tab, select "Internet" >choose Custom Level > From the "Security Settings to enables the setting.
Occasionally, virus installed on your computer without your permission. It can change the setting of your computer by modifying the registry. Fixing it is easy, ErrorFix was designed for users with no computer savvy. They can clean up registry without the help of technical personnel. In fact, ErrorFix has the ability of fix all errors above. Have a wonderful experience of fixing Hotmail slow and freezing now.
on Sep 15, 2010 • Computers & Internet
2helpful
5answers
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
1helpful
2answers
My hard drive is clicking alot & I am getting alot of freeze ups/ super slow response time , white faded screens etc. Need to replace?
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no MOISTURE in the air lines then give the hard drive a firm tap on the side to free it up
test or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure the connections are securely seated and they are not bad/faulty and no dust built up I would simply replace them
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
defragment your hard drive will speed up your computer
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
don
Lg dare is really slow. when i try to send a
when i send a message, the message sent thing stays on the screen for seriously like 45 seconds its ridiculous...and they have already done the upgrade of the software and it didnt work
1helpful
Brand new samsung dryer not drying fast enough took 2hours to dry and still damp. the dryer was on more dry, high heat,
try checking your vent exhaust
and vent tube
soometimes airflow is slowed by clogs and build up causing long dry times
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
2answers
MP3 Player freezes
Before transferring your music into it's phone; in it's current location, right click on the white background, go to view and then click on details. Now you should be able to see more detailed information about your songs. The next thing you should do is right click on the on gray bar column where it defines the name of your song, the artist name, and the size, etc., etc. Right click on the song you want to transfer over to your phone. Song names cannot include any symbols for it will cause your phone to freeze as you have mentioned. I was once in your situation. You can either do it this way or rename your music files with Itunes or any other program.
My sansa wont boot up
Re - Format Your sansa drive
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
