Question about Neff Ovens
NEFF H5972N0GB Built in Microwave oven. The oven shorts out as the door switch operates. The appliance cab be switched on (at the spur) with the door switch depressed or open (i.e. door closed or open), but the minute the door is opened or closed, the appliance shorts out.
Posted by barriepea on
5 Related Answers
Anonymous
  • 640 Answers
SOURCE: 5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Posted on Aug 17, 2007
Anonymous
  • 130 Answers
SOURCE: my oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Posted on Jan 06, 2008
Anonymous
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
kibonghe
ronny monnaie
  • 25 Answers
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Posted on Feb 04, 2009
Anonymous
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Is it still safe to use as the light is broken, I have tried 3 bulbs.
Hello Carol;
My name is Peter. I am retired field service appliance technician.
Your oven requires a special oven utility bulb. If you have used common house hold bulbs they can not handle the heat.
Lets assume you did use a special utility bulb. On the face of your oven when you open the door is a little plunger button (Switch). This is may be a dual activation switch if you have a self cleaning feature. So, you will have either one circuit for the light or two circuits, one for self cleaning and one for the light.
The circuit for the light is a separate circuit and is strictly for the light to turn on when you open the door and turn off when you close the door. You can operate your oven safely without the light working.
You may have a short, but I will bet on a bad oven door switch.
Go into the following website and put in your model number. You will get diagrams and component part numbers.
Your model number is located on a label either on the face of the oven when you open the oven door or on the side of the door. Water Filters Lawn Garden Appliance Parts
Mar 11, 2016 | Neff Ovens
Is there a fuse or re set button on my neff combo micro wave, ive just cleaned it and now have no power to it, i have checked the fuse
ISOLATE THE MICROWAVE DO NOT OPEN AS YOU CAN RECEIVE A SHOCK FROM THE INTERNAL CIRCUITS.
Check the mains fuse in the plug, remove fuse and put into a working appliance, if it works. Buy a new microwave, as the internal circuit has a fault, and depending on model, the cost of repair is usually very expensive. Unless you have an appliance insurance. leave repairs of this type of appliance to the proffs.
Check the door is closing properly, as a switch is activated by the colsure of the door, some cheaper microwaves use plastic and this can fracture, causing the microwave to not work. The front display should light up regardless of the switch position. The fuse inside can be 10 to 15amp slow blow, if this is the case, scrap the appliance as it requires specialised equipment to fault find and carefull handeling discharging capacitors and so on. A reasonable level of knowledge of electronics is required. hope this is of assistance.
Johnf1
May 17, 2011 | Ovens
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
The oven would not start
It doesn't work at all If your microwave oven doesn't seem to work at all, check these: 1)Fuses---- Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. 2)Door switch--- If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. please do not forget to rate the solution.thanks.
Jun 12, 2009 | Ovens
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Microwave oven
The high voltage capacitor is probably shorted, (large, silver, oval shaped part). typically .98mfd to 1.02mfd
Jun 03, 2008 | Ovens
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
Ovens Logo
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
