Acer Aspire One Netbook Logo
Posted on Feb 14, 2011
Synaptics touch pad on acer netbook stopped working drivers reinstalled Dual windows xp and ubuntu; not working in either Pointer seems to manage a twitch during loading, then nothing. USB mouse now plugged in and OK
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
346
Points
10
Mouse pad won't work
whenever any device stops working first try re-installing it as follows:
go to start -> control panel -> devices -> press on + sign to open each device.
scroll down till u reach ps/2 mouse, right click mouse and release on uninstall., switch computer off (hard reset) and back on windows will then re-install driver during boot - up.
if that doesnt work go to laptops website and download its touchpad driver (most called synaptics) and install.
1helpful
Double tap working
do you have a 'synaptics based' touch pad?
try;
- re-calibrate your mouse properties in control panel
- reinstall the touch-pad driver
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Good Morning: I have an Acer Aspire 5920
As by your description, the FN F7 key combo did not solve the problem. Please restart the machine , press F8 then select from the list "Safe mode" then press enter. Then see how the Touch pad reacts in Safe mode. If it works perfectly in safe mode, we can assume you have a software problem that is preventing it from working in normal windows mode.
Please download and install the latest BIOS for your machine. The E525 has a issue where the TP just stops working, upgrading the BIOS solves the issue on the E525...
Acer Aspire 5920 3813 BIOS
Please install one of these drivers for the desired Operating system...
Acer Synaptics Device Driver Windows XP
Acer Synaptics Device Driver Windows Vista
Acer Synaptics Device Driver Windows 7
Acer 5100 win 7 synaptics tochpad driver no click
Navigate to Device Manager Start >> right click computer >> Device manager I believe for 7
If the device does not is missing completely, your touch pad needs to be replaced
If it does show up completely uninstall the driver, reboot and reinstall
Acer Aspire 6930 Touch pad not found
Please reinstall your Touch Pad Synaptics Pointing Device Driver then restart your machine.
Thanks
I can't get the touchpad to work properly. I have
hello
If rest of your window is working fine and the problem is with the cursor only then you have to uninstall the touch pad driver then reinstall it.
If you don't have the driver you can download the driver from Acer's website.
thank you
112helpful
2answers
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
