Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
I have a new Ge profile modesl pdw7880 dishwasher. It does not clean the dishes. The glasses have a milky white film and spots. The black arm on the bottom has a white coated build up. Also there is a strange nosie that sounds like vibration coming from the dishwasher every time I run it. My old dishwasher performed excellent this one is terrible.
Posted by barbj218 on
Anonymous
    Novelist:
  • 175 Answers
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 01, 2011
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Our GE Dishwasher is brand new and everytime we wash dishes the dishes leave a residue of cloudy white in all of our glasses. What can we do to fix this problem? Thanks so much! This is our Model GE...
heatman101
Feb 12, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Our Ge profile Dishwasher is not cleaning the upper level dishes, mostly glasses and coffee cups. The insides are bumpy with dried on food. We have cleaned the bottom filter.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile PDW8480J01SS doesn't dry the top rack, even though the detergent packs I use have rinse agent. help!!! there is also a white residue on the glasses when I am hand-drying them.
heatman101
Aug 23, 2010 | GE Profile PDW8400J Built-in Dishwasher
MIlky residue after complete
heatman101
May 09, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Dishes are no longer cleaned properly. They have a white milky film BUT if hard water is the problem, why were they coming out perfect for the past 8 years?
If the film is only on glass. wash the glass with a citrus cleaner, if they get clean then your glass ware may have been etched by your had water and the detergent from your dishwasher is staying in the etched glass.
If this is not the case, then your dishwasher might not be getting the proper volume of water, witch will decrease the pressure of the wash arm or your spray arm might be dirty.
Jan 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Glasses have milky film after running the dishwasher.
This "milky-like" film is hard water build up in your dishwasher that is depositing it back onto your dishes. To solve this you can get the product called Lemi-Shine at any store or on line. The first time you need to put about 2 heaping table spoons into the dishwasher with no dishes in it and run a normal cycle. Then load and put 1 table spoon in it for about 4 times and you will see the "milky-like" film go away. After that you will need to do a Lemi-Shine cleaning 1 a week. The Lemi-Shine has the directions on the container. I know this cause I use to have the same problem at my house and this works. Good luck. And thank you for the question.
Aug 17, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Dec 21, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
