Question about Kenmore Washing Machines
Water slowly seeps into wash tub while unit is off
Posted by murfstar on
Hans Pearson
  • 2,510 Answers
Your inlet solenoid valve is leaking either due to a damaged seat or possibly dirt trapped in the seat. Check the valve and replace it if need be. Till you can get around to it, keep the supply faucet closed.
Posted on Feb 14, 2011
Why is the washer slowly leaking water into the back of tub between washes?
There is grit in the water valve holding it open just enough to allow the water to seep by. You should get a filter system for your washer and replace the water valve, Grit is not covered by most warranties.
Mar 13, 2016 | Maytag Bravos XL 4.6 cu. ft....
Frigidaire front opening washing machine fills with water
Hi, if it fills slowly overnight with clean water you may have to repalce the solenoid valve as it may be seeping water through, If however it fills with dirty water you may have water returning from the sink, if this is the case raise the level of the grey outlet pipe
Mar 10, 2013 | Washing Machines
My washing machine drains all the water at the end of the wash, but then slowly starts to fill back up. What is causing this to happen?
Hello cowmeag - From what you are describing, there are two possibilities: the valve assembly may not be seating properly or the Main Control board is sending voltage to the valves. If the valves do not seat properly, water will seep paste the valves and gradually fill the unit. I would recommend unplugging the unit. Wait approximately ten minutes and restart unit. If it still slowly fills, more than likely you water valve will need replacing. Otherwise, the dishwasher has a possible Main Control board failure.
Mar 08, 2013 | Frigidaire Affinity ATF7000E Front Load...
Top loading washing Kichenaid leaks water into tub; turn off cold water and stops leaking; how to fix
Hello Keith, If what your experiencing is after wash the tub is empty but you look a day later and their is water in the tub without using the washer,the water inlet valve on the back where the hoses connect to is not fully and seeping water slowly but steadily into tub and must be replaced. The part number for that valve is 285805 it could be purchased at your local appliance parts store or online at searspartsdirect.com repairclinic.com apdepot.com assuredparts.com appliancepartspros.com I hope will help you to fix your washer, Gene
Aug 09, 2011 | KitchenAid KAWS700L Top Load Washer
Found machine with water in it
If machine was empty at end of last cycle, replace the inlet water valve, as water is seeping by, causing your water in tub situation.
Mar 02, 2010 | Maytag Washing Machines
Water that seeps into washer after cycle is done
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Vic
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Amana ALW880QAC is leaking at bottom of tub
that is a pricey repair.not an easy repair.your best bet is to buy a new machine.
Mar 09, 2009 | Amana ALW880WH Top Load Washer
Washing Machines Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
