It over heats too quickly - Office Equipment & Supplies
Posted by lashawnlamar on
pl2323
    New Friend:
  • 89 Answers
Use a clean cloth to hold the bulb when replacing it. Our hands have oil and dirt. This would cause the bulb to overheat.
Posted on Feb 17, 2011
How can i get the machine to heat up quickly
What do consider quickly? it takes on average 3-5 min from cold to be close or at popping temp.
Mar 23, 2016 | Nostalgia Electrics Hard Candy/Sugar Free...
Battery heat up quickly on Nokia Lumia 800
This is fairly common with heavy use. If it is hot even to where you can't keep your hand on it, then you may want to replace the battery. If you can keep your hand on it without hurting yourself I wouldn't worry about it.
Nov 23, 2013 | Nokia Lumia 800
My spa will not heat up to 102 degrees. It's been at 80 for the past hour and the previous days its had no problem heating quickly. What am I doing wrong?
Is your spa still not heating?
If the problem persists it indicates that your heater element is bad.
We have instructions on how to test it here
Sep 23, 2012 | Pool & Spa
My car is over heating, also when I turn the heat it blow out cold air. What should I do?
Sounds like the thermostat may be bad, which means the coolant isn't getting into the engine block and heater. Does the heat gauge ever go really high and then drops back to normal quickly? If so, the thermostat is the quick and easy fix.
Sep 19, 2010 | 1997 Ford Taurus
Why does the temp drop
thats easy its the law of energy and surface area you have a deep fryer that has large area of aluminum and aluminum conducts heat very well on the plus side it heats the oil quickly. on the down side it loses heat very quickly too so the machine is always turning on and off to balance the heat loss. when you place food into it that drops the temp also.
Dec 21, 2009 | Masterbuilt 20010406 Deep Fryer
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
Dryer not heating uo.
Quick solution (and inexpensive): check the vent and vent hose to make sure it is unobstructed.
More costly solution: Replace the heating element.
Hope it is the quick solution!
Good luck.
May 18, 2009 | Dryers
Fai think its the fan ..but i cant go on playing music or watching videos or it will heat up quick!??
Yes it will heat up quick, and when it doese the heat can cause big damages on the hardware. Replace the fan before doing anything else!
Good luck to
If you find my answer helpfull, dont forget to vote
Dec 12, 2008 | Acer Aspire 5050-3242 Notebook
Cpu heat
buy a notebook cooler to minimize the heat of your laptop
like this
cheers
CHARCOIS
Aug 30, 2008 | Computers & Internet
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
k24674
