Dell Inkjet 720 Printer Logo
Posted on Feb 14, 2011
Which of 4 ports do i plug my 720 printer - Dell Inkjet 720 Printer
When i try to print a paper a popup comes up and says that my printer is not connected to my computer, I have tried unplugging the power cord and usb cord an restart the computer nothing works
See if you can reinstall the printer. Try deleting the printer in the control panel and then reinstalling it. Also try plugging it into another USB port.
Hooking the printer up to the computer?
yeah you should only be looking for two wires one is power pretty obviously goes to the wall nand the other is either a usb or pci cable which plugs into the corresponding port on the computer this is a link to the users manual there may be a picture in there to help you out
Robb
1helpful
Dell insprion 1525 won't print to any printer wireless or direct usb connection
Have you checked your printer port settings in the windows printer configuration page? It appears that this may the first place to start. Most USB printers are configured to a numerical usb port. Make sure your usb printer(s) are not configured to LPT or serial ports...
I have a dell 1536 laptop that has never been able to communicate with a printer. I thought I just had one that was too old. I am running Vista and just bought a brand new Cannon printer, still no luck....
Is it a USB printer? Does your USB port on your Laptop work when you connect any Flash memory to it? If so make sure you have installed the current drivers for the printer prior to plugging it into the Laptop.
2helpful
3answers
Toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
Dell 720 printer
Delete the printer icon and disconnect the USB cable. Restart the laptop, reconnect the USB cable to see if your laptop recognizes the printer. If so, install the printer driver. If not, probably USB cable or port issue. Hope this helps.
1helpful
Got a new Del 720 printer. Using XP. Test page
go to printer properties and do a alignment and it will print like its made to do.
720 dell. can't get it to print. light is blinking. I unpluged printer and computer still doesn't work. what should I do?
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
I have a dell 720 printer and even after I replaced
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
1helpful
2answers
Dell 720
Lately dell printers use a power pack that slides into the left rear of the printer and is universal to many different Lexmark & Dell printers. This since about '02. These packs make 30 volts DC. Google part # 15J0307 and see if this is what you are missing.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
