To increase the volume of video on your phone, play the video and use right side of the menu button to increase the volume and the left side to decrease the volume also.
You can sometimes use ear phone. This also enhance the volume of your video.
Hope this solve your problem.
Regards
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Disassembly Required
Ok for whatever reason breaks on the printed circuit board have occured. Expose the contact points of the rca ports. resoldering these spots on the pc board will do the trick. 'HINT' resolder all contacts, there should be 3 or 4.
As for the volume check for dirty residue below the surface of the switch face(s) and or increase tension spring found below switch face.
