Question about Krups Food Processors
You have a short in cord so whats happening is your only geting half the power you can but new cord for it and rewire it in processer.
Posted on Feb 14, 2011
After it stops,does the power remains on and food processor stops.r the power automatically turns off.If the power to processor is on but it stops running,then it can be weak or faulty motor in the processor,but if the power turns off then it can weak motor controlling circuit board in the unit.It has to be checked.
In most of the cases its faulty food processor motor.This motor gets weak,so it stops .Its just weak so it starts but cannot run further to it stops.----------- Check out.Keep updated.Thanks.
Posted on Feb 15, 2011
Nov 30, 2015 | Krups Food Processors
Mar 21, 2015 | Krups Food Processors
Aug 01, 2014 | Krups 705 Optipro 8 Cups Food Processor
Jun 22, 2013 | Food Processors
Apr 03, 2012 | Krups The Butcher Shop Food Processor
Sep 12, 2009 | Cuisinart Food Processors
Jun 08, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Nov 17, 2017 | Krups 705 Optipro 8 Cups Food Processor
622 people viewed this question
hi, the power cord is fine, the machine has electronic timer, Evan i change the setting time example for 5 minute the machine works for 3 second and stop.
The problem is in the engine speed sensor at the bottom of the engine. This is a small PCB board and 4 wire cable that goes to the main PCB board. To connect the cable again, it is necessary to disassemble the whole Krups and connect this cable. As the cable drop out from the connector because of engine vibration it would be good to glue it.
MS-5925797
