Question about Kato Toys
I have the 20-650 railroad crossing with the additional 20-651 track for two trains going different (or same) direction. It works fine when either track is powered, but not when both are. Any idea how to remedy this? Also, some of my interior car lights have burned out and I am looking to buy just interior light bulbs, not the entire set (11-204 or 11-206). Thanks for any help.
Posted by robert_t_lyn on
5 Related Answers
Anonymous
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Anonymous
SOURCE: power locks interior lights &idle
The same thing happened to me...its a fuse under the hood under the black box.There should be a little yellow thing holding two small fuses...check those ok.
Posted on Oct 04, 2008
Michael Anderson
  • 172 Answers
SOURCE: light bulb replacement doesn't work
Hi Liz,
The reason they want you to disconnect the power is to prevent shock while installing the new bulb. The door switch controls the light in the freshfood so you really do not need to disconnect power, just be careful not to stick your finger into the socket. In most cases the bulb is hard to get securely screwed into the socket. The moisture in the refrigerator causes defect in the metal around the bulb socket and causes the bulb not to make a secure connectioin. So to repair your problem you can first off make sure the bulb is securely screwed into the socket. If it does not work you can check the voltage at the socket for the 110 volts. You can do this with any volt meter if you have one. Sometime the new bulbs can also be bad, its rare but possible. If you are not getting the proper voltage to the socket then you may need a door switch. If you have another light working in the freshfood then the door swith will not be the problem. The door switch is the only power feed swith to the socket, so one of those two will definately fixYa. Good luck and have a great day.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
Anonymous
SOURCE: Bachmann HO train set not working
I realized that you can't use two left hand turnouts because they end up making a short when the come full circle!
Posted on Jan 19, 2009
Please research if it is ******* to photograph on rail road track in the United States. What is the dollar amount in the fine and how much jail time? Portraits printed are law breaking evidence.
it is not legal to be on railroad property anywhere in the USA. Railroads are used for interstate commerce and the law is enforced. The laws pertain to trespassing and the fine and sentencing is subject to many conditions. If a photo shows someone on the railroad right of way, there are many issues with getting the photograph into evidence. There has to be a chain of evidence.
Apr 14, 2017 | Miscellaneous
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
Today while driving to school i crossed two sets of train tracks. when i passed over the first set my head unit turned off and said system error resuming. I then turned the unit back on and it worked fine...
Sounds like going over the tracks might have knocked a wire lose behind the dash. The only way to know would be to take out your head unit to reveal what's behind it. Make sure all the cables are securely fastened and it should work again.
May 03, 2011 | Power Acoustik PTID7002NR Car DVD Player
2004 dodge ram 1500 2WD front end making a metal on metal sound going over small surface bumps like rail road tracks. I have had trhe front end inspected 3 times for the possible cause. All garages tell me...
Interesting problem although aggravating. Take a bottle of Dawn washing up liquid,(or equivilent) and drive the vehicle to the nearest railroad crossing. Squirt the soap all over the mounting rubbers on the shocks and anti roll /sway bar. Drive across the railroad crossing and listen for the noise. if none then you have narrowed the search. next do a simple process of elimination regarding the soaped rubber mountings etc.
However,a Dodge noise making rattle when crossing any uneven surface can be caused by the front grille securing fixtures coming loose and allowing the grille to rub and vibrate on the sheet metal. I have an older Dodge with stainless steel wiring fitted to resolve that same problem! It's not an obvious fault but it really is an aggravating one.
Jan 09, 2011 | Dodge Ram 1500 Cars & Trucks
The wheels on my son's train only makes clicking noises
wheels are stuck and the gear drive is jumping over the gears
Feb 09, 2018 | Toys
2001 Kia Optima - Train sound underneath
I had this problem it was the control arm in the rear of the car.
Feb 03, 2009 | 2001 Kia Optima
Shaking wheels
It's something in your steering components or you tires. I've seen both. If your tires are pretty good, it could be your steering stablizer. It's like a shock asorber for you steering system. There also maybe some components wearing out in your steering system too though casuing the stablizer to wear out or unable to to asorb the shock from the bump.
Oct 19, 2008 | 1995 Ford F250
Toys Logo
Top Kato Toys Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Kato Toy Expert? Answer questions, earn points and help others
