Question about HP DeskJet D1460 InkJet Printer
The problem is my printer is only printing 2/3 of a page. its missing on the right hand side of the page. Ive done numerous test pages & they've come out fine. It seems to only happen in my email page.
Posted by william marshall on
Anonymous
    New Friend:
  • 80 Answers
The settings have been changed.
The fastest way to rectify this fault is to uninstall the printer drivers and reinstall.
Restart the computer after you have uninstalled the printer software before reinstalling
the software drivers again
Posted on Feb 14, 2011
Testimonial: "Thanks a lot for your your expert advice.Working fine now. Will definately use you again,when I have any probs. regards w marshall "
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
How can I do a 2 sided print
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP OfficeJet Office Equipment & Supplies
My printer simply wont print, I just get blank pages even when printing the test page. I have tried cleaning, deep cleaning nozzle alignment, everything!
HI there,
It sounds like you've done everything right, and it still won't print. Your printer is dead - and you need a new one.
May 19, 2011 | Office Equipment & Supplies
How do I print double side
Then print pages 3 & 4 on both sides and repeat for the rest of the document.
I suggest you try a test page first to get the printing right way up so the page reads correctly.
Dec 06, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
Can I print on two sides with the Artisan810?
Dec 06, 2010 | Epson Office Equipment & Supplies
Hp photosmart c4580 (new) is not printing bottom line of page, also not printing centrally it misses words down the right hand side connected to advent windows vista can you help
Try printing a test page, if the problem appears there too, it could be a print head problem. But try a new ink cartridge first, to make sure that's not whats defective.
Since it's new, you should consider exchanging it while you can.
Sep 19, 2009 | HP Pavilion dv6000z Notebook
Incomplete Printing
It depends on the page you are trying to print. Some pages do not like printing everything on the page. What I have done is printed to PDF (with images) and then printed the PDF. You can find free PDF printers here:
http://www.google.com/search?hl=en&q=pdf+printer&aq=f&oq=&aqi=g%3Ap1g9
Jul 12, 2009 | Office Equipment & Supplies
Not printing whole page
Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
Dec 15, 2008 | Lexmark X2600 InkJet Printer
Printing
Some net printouts need to be printed in Lanscape mode. For example I just selected Print Preview on this page and some of the right side is missing. You can use page setup to select landscape.
Hope that helps...
Geno
Mar 10, 2008 | HP PSC 1410 All-In-One InkJet Printer
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet D1460 InkJet Printer Logo
efs_perpends
efs_perpends
k24674
