Question about Garden
I have a ride on mower with a 14.5 HP B & S OHV engine. It is very hard to start when cold as it kicks back on the starter motor.
Posted by morgan404 on
  • morgan404 Feb 15, 2011
    I am sure its not a flooding problem, and I was told that the valve adjustment could be out but I could not relate that to the problem, but as you have explained that the compression release is dependant on the valve adjustment it now makes sense to me. Thank you
Ralph
  • 130 Answers
You could have more than one problem so I will list the two most common. The compression release is built into valve train and if the valve adjustment is off, the starter motor will not turn the engine over under full compression. You will need to know the model no. of the engine to get the proper valve settings. Also, there have been flooding conditions with some of the carburetors that will cause the combustion chamber to fill with fuel and the engine will not turn over. Hope this is enough information to get you in the right direction.
Posted on Feb 14, 2011
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Starter kicks in but wont turn engine acts like too much compression,battery is fully charged
Very can be if it is an OHV engine that either the valves are needing adjusting or the decompressor has failed.
Most 4 cycle small mower engines have decompressors to help with the starting, These are only active at start-up and does not effect normal engine compression when running.
May 18, 2015 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I need a starter .i have a poulan 15.5 hp ohv i/c rider mower briggs& stratton how much does it cost
Before you shell out a bunch of money for a starter, unless you are sure that is what's wrong, there are a few things to check out first:
1. Safety switches
2. Starting solinoid
3. Ignition switch
4. Battery
Those are for if you have no response whatsoever. If it turns, but barely, check the following:
4. Battery (could have one bad cell and still hold some voltage, try jumpstarting the motor)
5. For over head valve (OHV) engines, adjust the intake and exhaust valves.
I hope this helps.
Aug 02, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Locked down motor
Unfortunately it sounds like you threw a connecting rod in other words a blown motor. The connecting rod has become disconnected from the crankshft and is jammed up between the case and the crank itself, the engine must be dissasembled and rebiult.
Nov 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
1993 Yardman riding mower - motor won't turn over
Yes there is. I don't know from your description whether or not this has a
OHV engine. but if it does this is a common problem. over time the valves
get out of adjustment. thus causing hard starting. the valve lash will have to be adjusted to specs. what happens is the (ACR) automatic compression
release fails to open the exhaust enough thus causing hard starting.
and it kills batteries and starter gear teeth.
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
ray gallant
