Question about Crate FlexWave FW120HS and FW412 Half Stack
My crate FW120HS has suddenly started giving me loads of reverb, and i have no idea why. Iv not changed any effects or my set up. Its just suddenly happened. Any Ideas?
Posted by mikekaperys on
Fred Yearian
  • Crate Master
  • 5,603 Answers
This has a digital reverb unit. The settings are subject to get clobbered I suspect. I don't know if you are using foot switch for the reveb control... You may also have a cable that has come loose...
Here is a link to schematic for your unit:
http://elektrotanya.com/crate_flexwave_guitar_amp.pdf.pdf/download.html
Notice that the reverb is set by DC voltages from teh setting pots that go to the DSP chip. These setting pots receive voltage from a 16 volt ZENER regulated source. First thing is to CHECK that voltage. If the Zener has opened and you find much over that 16 volts, that is your cause of the problem.
The circuitry is on page 1 in the 3B to 3D lower left of the page.
Posted on Feb 14, 2011
I need a crate 06b885-20 effects board. were can i get one
Guitar center used gear
zzzz sounds
reverb.com
sweet water.com
craigslist
Feb 04, 2018 | Crate Music
What preset effect number is best for karaoke?
Always use echo and reverb, or just reverb for inexperienced singers. If I remember right this is from effect 19 but this is a very inflexible set-up with no control over the effects, just presets. You'll need to listen and decide what is best. You may also try chorus as with a decent effects unit this can be very effective plus a bit of reverb and echo.
Different songs like different effects and we will chop and change even in a single track when live mixing professional acts.
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Crate amp head loose spring
its the reverb tank spring, look where it is connected on the other side. this will give you an idea as to where it was connected. solder it back on.
May 10, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Mar 13, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
How to set a sustainer in zoom g1xn?
There is not a sustainer as such - However you can use the Decay parameter in the reverb module.
  1. Set the Module Selector knob to Reverb
  2. Choose a reverb type from H = hall, r = Room, s= Spring, A = Arena, t = tiled Room (arena 1 - should do it quite well)
  3. Turn the module knob to decay And rotate the value knob until the number 30 shows
Apart from that you may get a bit more sustain from using different Drive modules - the distortion drives such as Ed will give a longer sustain than the clean accoustic drive sounds.
Using heavier gauge strings on your guitar will also give longer sustain but make it a harder to play fast.
Feb 21, 2011 | Zoom Samson Technology Zoom G1XN Multi...
Crate 100 head. Reverb doesn't work.
Check the input RCA plug going into the reverb tank (silver box with two wires connected to it). Make sure the amp is off when you do this. Sounds like the output is working fine if hitting the amp does it.
Jun 19, 2009 | Crate Music
Crate gt 30 amp reverb wire loose. whrer does it connect?
If its the input reverb tank wire or output reverb tank wire just reconnect it (if the amp has a reverb tank).
Feb 27, 2009 | Crate Music
Crate FlexWave FW120HS and FW412 Half Stack Logo
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
