Question about Reddy R60A Utility Heater
My heater will fire up with no problem, run for 5 - 15 minutes then shut off. I can unplug it then plug it back in and it will run for another 5 - 10 minutes and shut off again. There's no theremostat so it no like it's reaching temp and shutting off. Whats up?
Posted by michaelgigli on
Kelly
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Download this service manual:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
You may have a dirty Photocell as discussed on page 19 but you can have other issues. The manual will help you sort it out.
Things to look at are:
  • Photocell
  • air filters
  • fuel nozzle
  • fuel hoses
  • fuel tank cap
  • fan clearances
Everything I listed is covered in the manual link at the top of this post.
Thanks for choosing FixYa,
Kelly
Posted on Feb 14, 2011
Heaters fires, stays on for 10 seconds, then burner turns off
Just had the same experience.
1. Pull the top cover off and try gently wiggling the printed circuit board on the right side top. Pull the thermostat mounting board too if it helps. Be careful as it is still live as you are doing this. If it fires, unplug it & remove the board from the unit. Get a magnifying glass and a good light and go over the solder connections on the back of the board, ALL of my connections where the harness plugs into the board were cracked. Best as I can figure, the board is mounted right next to the power vented flue discharge and it is extremely hot there and must expand & contract with heat especially if wind is blowing the heat back onto the unit. Re-solder connections & mount the board somewhere else in the unit.
2. The igniter assembly acts as a thermocouple, which is to say it "proves" the flame to the unit telling the gas valve to stay open and the spark to shut off as long as the thermostat wants the unit to run. That component may have failed & requires replacement.
3. The flow switch (Pressure sensor) proves water flow to the unit saying it is ok to fire. I've replaced mine twice due to them busting open, but that can also hold out the unit if it doesn't sense flow,however but I doubt that is the culprit. It is easy to test, just make sure the pump is on, jump the wires & turn on the unit. MAKE SURE to put them back on after testing as the water will boil very rapidly if the unit runs with no flow which is extremely dangerous.
I would check these components in that order.
Jul 14, 2009 | Hayward 100kbtu Pool Or Spa Propane Gas...
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater keeps shutting off !!
I have model 5532, but I think they all have the same problem. There seems to be a safety device in the ceramic heater that turns off if it gets too hot. It "remembers" when this happens as well and will shut off until it is unplugged for 10-15 minutes.
This happens on even lightly used heaters if used in dusty conditions. Dust builds up behind the ceramic heater and the lack of flow causes it to overheat. The unit must be dismantled and the dust brushed/vacuumed out. The good news is that not only will the heater work again, but it will have better airflow too!
To do this, tech support and other people say to "clean the rear grill", but my rear was not dirty. The front grill had some dust that I vacuumed clean, but did not help. In my unit there are no filters before the air goes through the heater element. The problem is in the center of the heater. Taking out the internal fan (four screws on the sides of the squirrel fan box), I could see that the radiator was over half covered in dust. I cleaned that dust out using a shop vac and the problem went away.
Opening the heater was a little tricky, two of the screws were triangle head screws. Once inside, however, it is a simple proceedure to remove the fan. Of course, you should unplug the heater and wait a while before opening it up to make sure there are no electrical charges stored in the unit.
Dec 27, 2007 | Lasko 5132 Ceramic Compact Heater
Reddy R60A Utility Heater Logo
332 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
