Question about Sansui 32" TV
KYUUTEN LCD 324H - ALL CHANELL NOT COMING AND STORE AFTER DETUNE POSITION. AFTER FINE TUNE PICTURE IS OK
Posted by utpal03 on
Cannot auro tune the new chanels on my chang hong tv. The audio works but tge picture format is invalid. What do i need to do ro get the picture.
Have not got 1 of these so this is an educated guess:
Go to settings, select tuning or chanel tuning, opt for the auto tune, follow all directions give to complete.
Mar 04, 2016 | Televison & Video
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
Apr 22, 2009 | Logitech Harmony One Advanced Universal...
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
PURCHASED 52" LG LCD HAD A GREAT PICTURE.ALSO HAVE DIRECTV. TOUCHED THE MENU BOTTON SAW THE AUTO TUNING, THOUGHT THAT WOULD BE A GOOD FEATURE. WENT AHEAD AND LET IT RUN THROUGH ALL THE CHANELS. NOW IT...
Because you have DirecTV there is no need to use auto tuning. You simply changed inputs on the TV when you started auto tuning. Just use the input button on the remote to go back to the Direct TV receiver. Most likely it will be under Component (Color Stream) or HDMI input.
Dec 31, 2008 | LG RU-27LZ50C 27 in. HD-Ready LCD...
37' Dynex LCD flat tv, sound doesnt work on some chanels.
There are few sound settings on most tv's the most common is D/K and B/G the one that you want is B/G it should be under tuning or sound settings.
If you have any questions please dont hesitate to ask
Nov 27, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Sansui 32" TV Logo
Top Sansui Televison & Video Experts
Paul Bade
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
