Question about Tricity Bendix AW1400W Front Load Washer
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for reaching brushes in situ?
Posted by tonylake2 on
Hans Pearson
  • 2,510 Answers
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Posted on Feb 14, 2011
How to take back off tricity bendix aw 1000 w
Tip the machine on it's side and fit it from underneath. It's a bit fiddley.
Dec 13, 2012 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Tricity Bendix AW1000W Front Load Washer
Trying to change the carbon brushes but can't find a socket the right size any ideas?
all done it was the brushes on both sides of the motor and borrowed a tool set to do it only cost £7 each and the machine is back on
Apr 28, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
Bendix 800 autowasher
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Paul Bade
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
