sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Josh
Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom..
Bill
[email protected]
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
