Question about Canon PIXMA iP1500 InkJet Photo Printer
My iP1900 cannot print. Service error 6000 appears.
Posted by daviscayuhen on
5 Related Answers
Anonymous
SOURCE: Canon MP830 Service Error 6000
I have same problem affter update internet explorer version 7 from 5.6 message in screen error servive 6000
Posted on Apr 17, 2008
Anonymous
  • 135 Answers
SOURCE: Service error 6000
I can't tell you specifically what you should do to try and repair your printer, but I do have one suggestion, a link to a Service Manual and a probable reason why a service tech wants to charge you so much for a repair. If you look in the service manual, here is what it says regarding error 6000: ------------------------ Line feed error [6000] Solution (Replacement of listed parts, which are likely to be faulty) - Timing sensor unit (QM2-2683) - Timing slit disk film (QC1-6229) - Feed roller ass'y (QL2-0925) - Platen unit (QM2-2202) - Logic board ass'y (QM2-2670)*1 - PAPER FEED MOTOR (QK1-1502) ------------------------ In other words, somebody looked in the book and quoted you a price to replace all these parts. One very common problem for printers is that the paper feed rollers develop a slick surface and don't grip the way they are supposed to. If you're experiencing a paper-feed problem, you can try buffing the rubber feed rollers lightly with fine sandpaper to help them grip once again like they should. (I've repaired many printers doing nothing more than this.) Below is a link to the Service Manual for your printer. Hope this helps. http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Posted on Aug 04, 2007
Anonymous
  • 214 Answers
SOURCE: Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 22, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Printer alarm goes off with error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Anonymous
SOURCE: mp250 error # 6000
put a whole lot but really lot of pages in the place to put them,that will push the cart downwards..and then it will work properly :D
Posted on May 05, 2011
Canon ip1900
5100 is Carriage (the part where you install the cartridge) Error. Try cleaning the long transparent film where the carriage slides through with cotton with alcohol.
Jul 01, 2013 | Office Equipment & Supplies
Fix code error canon printer ip 1900 series
Kindly provide more error details on your iP1900 series printer. Any error code? How many times light blinking?
Jun 27, 2013 | Cannon Office Equipment & Supplies
Mp250 error # 6000
May 15, 2010 | Canon Office Equipment & Supplies
I got an error with my canon ip1900 it says "paper jammed" i press Resume but nothings happen it's just repeating the error "paper jammed" what i need to do?
You need to open the printer and remove any piece of paper no matter how small. This can be causeed by even a small sliver of paper or even paper dust. It can also be the paper sensor but thats very uncommon.
Take the paper out fan and restack it. Then open up the printer and clean it as best you can. Put everything back in and close it up and you should be printing.
Mar 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
What does error 6000 mean on Canon MP630? It keeps telling me it's printing then the paper runs through without anything being printed on it. Thanks for any help.
Error 6000; Fehler 6000.
"Error 6000 is a mechanical problem of paper-input." (Hotline)
Remove paper-tray and check the rail inside as deep as you can see. (look for stuff!) Then try again. All other atempts are hopeless and send it to service.
Ich habe die abstrusesten Antworten im Net gelesen:
z.B. "Fehler 6000 bedeutet, dass die maximale Anzahl der Drucke erreicht ist und das Gerät wegzuschmeißen ist!"
Ich habe beim Service angerufen. Die meinten, es liegt ein mechanischer Fehler im internen Papiereinzug vor.
Das Gerät muss eingeschickt werden. Reparatur von eigener Hand aus nicht möglich.
Papiereinzug? Ich habe dann die Schublade einmal ganz rausgezogen und nach Störteilen auf der Schubladenbahn gesucht.(und gefunden!) Tatsächlich ging die Schublade danach sehr leicht wieder rein und der Drucker lief wieder. Alle anderen Recherchen sind m.E. vertane Zeitverschwendung!
Nov 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
PIXMA iP1900 - Color blue does not print
Dear kalium,
First, check ink level information in printer status monitor windows. Does message ink low appear in status monitor?. It could be the cyan ink has run out. Please replace the cartridge with new one
Dec 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Service error 6000
i have canon pixma ip1200, and I encountered the same problem with yours..SERVICE ERROR 6000, i tried to do a lot of things in my printer, i tried to Turn it on and off but it doesn't fix my problem, then I read that error came from, paper feed and roller..then i tried to pull and roll the soft plastic of the roller at the left side of the printer (if you're facing the printer, make sure the printer is off) then i notice that something's blocking the roller and then i turned the printer on and that's it..it works again, so far i've encountered the problem 2 times and i did the same procedure at the second time i encountered the problem.. I hope this will HELP you..;-)
Aug 03, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
old marine
old marine
efs_perpends
efs_perpends
