How can i connect my acer aspire 4310 to sanyo zlv-z4 projector
Posted by spraynseal on
Chris Hingee
  • Computers & ... Master
  • 32,281 Answers
You connect the data projector to the VGA video port on your Acer laptop. Power up the data projector then boot up the laptop and the video from the laptop will divert the video data automatically to the data projector.
You can toggle the video between the laptop screen and data projector and on both the laptop screen and data projector by holding the Fn key and pressing one of the Function keys that has a screen symbol on that key.
Posted on Feb 14, 2011
My plv-z4 projector makes a crackling noise when i plug it in
Hello
download its user manual to understand about these trouble. If the cooling fan's leaf has any break, this sound will be there. Click here to down load its user manual.
Feb 24, 2012 | Sanyo PLV-Z4 Multimedia Projectors
Just replaced the lamp on a sanyo plv-z4 and it still indicates lamp needs replacement. what do i do now?
reset your lamp counter. go to the menu find lamp setting. then reset. click OK 3 times
Oct 07, 2009 | Sanyo PLV-Z4 Multimedia Projectors
No captions sanyo projection tv
By captions you mean subtitles - this constraint is a feature of your TV and not the projector, If however you mean the menu text for the projector then you sometimes have to select s-vid or composite as the menu text (and the volume level) doesn't appear when you are using Component.
Jan 20, 2009 | Sanyo PLV-Z4 Multimedia Projectors
ACER SOUND DRIVER(ACER LAPTOP 4310 MODEL
i want aspire 4310 series sound driver so can u help me?
Aug 01, 2008 | Acer Aspire 3004WLCi Notebook
Overheat reset switch for Sanyo PLC-Z4 projector
check the other questions on this topic, I just posted a detailed answer, and that was based on another's answer.
Jul 22, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plv z4
look in the projector menu ( should not be backwards) and switch the view to front projection. It might be set in rear projection. That is what my viewsonic PJ-558 projector can do sometimes
Jan 26, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plv z4 shuts down
call sanyo tech department and they will help you increase the fan speed to cool the unit. This is done with the remote so it was pretty easy. Make sure your filters are very clean first (use compressed air or a co2 canister. Have not had a problem since, my units run on average 8 hours a night and have not shut down.
Nov 09, 2007 | Sanyo PLV-Z4 Multimedia Projectors
Computers & Internet Logo
k24674
