Question about Refrigerators
I have a Samsung side by side fridge Rs21 hdtts.Bought it in 2010. Made 8 cubes of ice every half hour. Now after six months since new makes the same amount of ice every HOUR AND HALF.Temperature of the freezer is exactley the same as before, -21 degrees C. Where can I adjust the freezer to tell the icemaker to dump the 8 cubes quicker. I saw that after half an hour the cubes are frozen solid and ready to dump.
Posted by leone386 on
Anonymous
    New Friend:
Threre is one reset button under the ice dispencing unit press it for three second and it will come to your previous setting.
Posted on Mar 02, 2011
Water/ ice issue
this problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Jul 25, 2009 | Maytag 25.6 cu. ft. Side-By-Side...
Motor freezes up
the issue is not with the motor to be honest you have probably wasted money buy a new fan motor ,
the fan only stops working when ice builds up and forces it to jam , the ice builds up as the defrost heater is more than likely faulty - very common issue on all uk samsung rs21 models ,
to rectify the fault totally its recommended to replace 4-5 components that operate the fridge cooling /defrosting system - sounds complicated but its really just 1-2 hour job for a skilled competent person
have a look at this video , also check the youtube chanel for same guy , there are lots of info on samsung uk american fridge freezers
May 10, 2009 | Samsung Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
I have a samsung RS21DGRS and it keeps makung a wurring noise from inside rear of the fridge compartment and now the water dispenser has stopped working .
very common issue on samsung rs21 models ,
repair kits have been available for a few years now
this video may help
how to dismantle samsung rs21
Sep 05, 2008 | Refrigerators
Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Mar 05, 2008 | Refrigerators
Samsung side by side fridge/freezer
BURY IT, NO ONLY JOKING, YOU DO HAVE A DEFROST FAULT, SAMSUNG ARE RENOWNED FOR THESE FAULTS, REMOVE THE BACK AND CHECK THE FOLLOWING, YOU WILL HAVE A DEFROST SENSOR, USUALLY TWO YELLOW WIRES WITH A WHITE BULD ON THE END, PUT A MULTIMETER ACROSS THE END OF THE WIRESES AND HOLD THE WHITE END IN YOUR HAND TIGHT, YOU SHOULD SEE THE RESTANCE CHANGING, IF NOT IT IS FAULTY, TO THE RIGHT OF THE EVAPORATOR YOU WILL SEE BLACK AND RED WIRES CHECK YOU HAVE A CIRCUIT THROUGH THIS ITEM, IT IS A THRMAL FUSE, IF THAT IS OK THEN METER OUT THE TWO HEATERS, IF THEY ARE OK THEN YOU HAVE A POWER MODUE FAULT. REGARDS ADVISOR
Aug 24, 2007 | Samsung RS2630SH Side by Side Refrigerator
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
john h
