Question about Dell Inspiron Mini 10 Notebook
While on the internet my mini 10 locked up, this happened twice. I switched it off and tried to switch it back on. The Dell logo pops up on the screen but then it remains black. I ran a diagnostic and the following error was reported 4400:011A SSC1_0_00_DISC_GENERIC_MULTI-CARD-TARGET NOT READY Can you help? Regards and thanks Bill
Posted by williamdwals on
  • 1 more comment
  • williamdwals Feb 14, 2011
    Hi Valentudor,
    My mini does not have a card reader in fact you need to use the ports to connect DVD player, mouse etc.
    The big question is how can I get it past the black screen and up and running.
    Bill
    No joy with that solution.........it's also out of warranty and being stuck in Saudi Arabia I don't expect much joy.....a friend of mine suggested the HD was shot, so looks liek it may be a new laptop requried.........thanks
    Bummer, but such is life........thanks for the advice.
    Regards
    Bill
Tudor Valean
  • 787 Answers
The error means that when the diagnostics were trying to test the card reader, there were no media cards(.ie SD Card from camera) in the card reader.
Posted on Feb 14, 2011
  • Tudor Valean
    Tudor Valean Feb 14, 2011
    Try turning on the computer with the blue Fn button pressed down with the on button and then release both at the same time. Then select boot up normally.
    If this doesn't work, then you need to contact Dell and arrange for them to fix your laptop (if it's still in warranty).
  • Tudor Valean
    If it were for the HD, then you would get some beeps at startup. I suppose you don't get any beeps, so I assume it's a malfunctioning motherboard. I think you need a new laptop since repairing it will be close to the price of repairing your old one.
Dell optiplex mini tower wont turn on
Make sure the power is being supplied from a working source, then check if the switch on the bottom-back of the computer is switched on. If the power button still doesn't work, try holding the button down for 10 seconds. Next, try switching the switch off, unplugging the computer for at least 30 seconds, plugging it back in, switching the switch back on, and pressing the button.
Apr 25, 2014 | Dell Studio Mini-Tower Desktop Computer
My battery is not enterely back in. What shoul I do?
First: This should be obvious, but if your computer is on, turn it off completely (if you were running on AC power).
Now, look for two switches on the bottom next to the battery. Move them away from the battery towards the unlocked padlock symbol. Take your battery out completely and then slide it back on. Once it's in securely, switch the locks back to the locked position.
Apr 28, 2011 | Dell Inspiron Mini 10 Notebook
ON mini 10 the bottom of the display doesn't show, where the start button is.
you might have change the location of the start menu or called task bar, try to press the windows logo key on the keyboard to show up the task bar. if it shows up you can drag it to the bottom of screen. if it is locked and cannot be dragged, right click on it and remove the check mark on lock the task bar.
Mar 09, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
99 chevy s-10 4x4 (push button) stuck in 4hi
do you have to truck in neutrul when trying to swtich back. some models you need to put it into 4 low then into 2 hi.
Jul 31, 2009 | 1999 Chevrolet Silverado 1500
Dell OptiPlex GX150 won't do anything.
try going to the bios by pressing f2 or delete key on the keyboard at the dell logo.
if you are able to enter the system setup screen, reset the bios.
to reset the bios, press num lock, caps lock and scroll lock so that all 3 lights on the keyboard are on.
press alt + e and alt + f keys.
press esc twice
then select save changes and exit.
also try booting through the safe mode by hiiting f8 on the dell logo.
you can also try booting through the dell resource cd or win xp cd.
Aug 06, 2008 | Dell OptiPlex GX150 SFF (GX150BLACK) PC...
Dell Inspiron Mini 10 Notebook Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
