If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged.
You can use the initialize option on the Menu to reset the Camera.
If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
Please let me know if you require any further assistance.
Thanks for understanding.
SOURCE: My Sony DSC-S730 is not detected by my PC?
dear,
check the driver and then reconnect it to pc.
if u have already installed the driver for it then plz reinstall it and then go.
regards,
SOURCE: Flash does not work
Please note that:
1. You can not use the Flash when the Camera is set
to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO
or Twilight mode is selected in the Scene Selection.
3. You can not use
the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is
fully charged and the flash is turned ON.
Please set the Landscape mode
or Snow mode or Beach mode in the Scene Selection and check if the
flash is working.
5. Try initializing the Camera and check if it works
normally.
NOTE: Initializing
the Camera will reset the settings of the Camera to the factory
settings including date and time. It will not delete any data saved in
the Camera.
6. Please press the Menu button on the Camera. Then, select
the SETUP menu and select the SETUP 1 option of the Camera. Then,
select the Initialize option to OK.
7.
Try to power reset the Camera and check if it helps to resolve the
issue. I suggest that you reset the Camera by removing the battery from
the Camera and inserting it after 1 minute.
8. If the issue still
persists then the Camera requires service.
Good Luck!!!!!!!
SOURCE: the flash of my DSC-S730 is not working
It is common problem with this model and flash board will be replaced.
Part number of flash board is as under..
A1444049A... ST BLOCK ASSY
Available in Part Store.
If you are not comfortable with replacing flash board then take camera to qualified camera tech as camera will be apart for flash board replacement.
Thanks.
Testimonial: "thank you for answering my question,i really appreciate it..God Bless"
SOURCE: flash not working on my sony dsc-s730
if u r finding flash green led glowing the discharging section of the camera is defective,replace the xenon tube and try.
SOURCE: User's Manual for Sony Cyber-Shot DSC-S730
You can download the user manual for this unit from this link.
http://www.nodevice.com/user_manual/sony/cameras2/dsc-s730.html
http://www.retrevo.com/support/Sony-DSC-S730-Digital-Cameras-manual/id/10732ci252/t/2/
