2006 Chevrolet Trailblazer Logo
Anonymous Posted on Feb 14, 2011
I have TrailBlazer 2006 ls , I want to fold the third row seats , but am unable to fold it , is it possible, if so please guide me as soon as possible. thanks Regards.
Anonymous
Level 3:
Genius:
  • Master 1,165 Answers
  • Posted on Feb 14, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1165
Questions
0
Helped
383436
Points
3606
The third row seats do fold flat. If you have the owners manual, it will have instructions on how to fold the seats. If you don't have a manual, drop by your nearest Chevy dealer and I'm sure they would be glad to show you how to fold the seat.
  • Anonymous Feb 15, 2011
    I did fold them but there is gap in between. How to fill this gap to use all the area by making it flat ???
  • Anonymous Feb 08, 2013
    You cant fill it , Its just like that. Bad design!
Third row seat in 2010 Lincoln mkt will not work. Checked all the fuses and they are good.
Third row power seat relay , power fold seat module , third row seat control switch . Anyone of these could be the cause for the seats not folding ? With a electronic module involved codes could be stored pointing to the problem . Your best bet mite be to take it to a qualified repair shop.
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
One of my third row seat does not fold down but the other one does. Could it be locked or jammed?
The seats shouldn't lock, its probably bound up. If you don't want to spend big bucks at the dealership, you might stop by a local automotive uphostery shop. Those guys work with seats every day.
Third row seats
Probably, but you could try on-line or at a Chevrolet dealer for a owners/service manual.
Why is there no power to third row seat?
Power 3RD Row Seat Problems and Tranny Shutter - Ford Truck ...
www.ford-trucks.com > ... > Expedition & Navigator
Mar 27, 2014 - Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition andLincoln Navigator SPONSORED BY: ... First the 3RD row seats won't fold down, noclicking, no sounds, nothing. I the fuses are good and there is power at the fuse box, but no power at the motors or switches. Based on continuity ...
3rd row powerfold seat stuck down - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 2007 - 2014 Expedition & Navigator
Mar 14, 2010 - 3rd row powerfold seat stuck down 2007 - 2014 Expedition ... 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator ... I also tried lifting the seat while my wife was pushing the button to raise it, to no effect. There is defnitelypower going to the motor but it just isn't ... Join Date: Feb 2005.
No power to third row seat on 2005 lincoln navigator - Fixya
www.fixya.com/cars/t12295627-no_power_third_row_seat_2005_lincoln
Apr 4, 2012 - no power to third row seat on 2005 lincoln navigator third row seat is ... U will have to replace the entire power seat transmission, there is no ...
Lincoln Navigator Review - Edmunds.com
1helpful
2answers
2004 ford expedition: changed battery, now rear seats will not go up or down. One is up the other one is down. They were working fine before the battery was replaced. Wifes car need to fix, she is...
Call the dealership and ask them how to reset the electronic on your Ford Expedition after changing the battery. Anything else is happen? Maybe like the radio wont turn on, hit the turn signals and the windshield wiper turn on. ***** things happen after replace the battery. I know what it is, it the darn wigits. GB you....stewbison
2answers
Can I install a third row in a Chevy TB 2004 that does not currently have a third row?
Nope. 3rd row was never offered with a trailblazer even the EXT modles.
I want 3rd row seats.
As a Auto body tech. Yes it is possible. It will take alot of work. You have a few ways to do this but it will take alot of modification. Find a third row seat and take it to a welding shop or apolestry shop and have a bracket built to bolt the seat down to the floor. Then take it to a body shop and have them drill the floor and install the seat. Or if you wish to tackle this on your own Good luck.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
