Question about HP Compaq Presario V3000T Notebook
Hp v3000 is no display - HP Compaq Presario V3000T Notebook
Posted by rinkus64 on
shiboram sardar
    President:
  • 1,812 Answers
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Posted on Feb 14, 2011
How to clear compaq v3000 laptop password cmos battery open but nothing clear please help mp immideataly jumper not found
>Go to this link:
http://www.syschat.com/download120.html
click on the "DOWNLOAD" button to download a program for CMOS reset...
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | HP Compaq for Presario V3000 Motherboard
What is a inverter on a presario v3000 moniter?
It's the controller for the light inside the screen.
The backlight in the screen is a high voltage device that needs the inverter to boost the voltage up enough to trigger the light to come on.
Usually if the inverter goes wrong you will only get a really dim display on the screen.
Apr 18, 2010 | HP 417065-001 - HP Compaq Presario V3000...
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Window is all black but the arrow is moving
Check the laptop booting with safe mode option and if you are getting display, then install the proper display driver for your laptop will solve your problem.
Dec 15, 2009 | HP 417065-001 - HP Compaq Presario V3000...
I Have a Compaq V3000 Laptops. The display is very dim. HELP!!
It miight be the backlight for this unit. It all depends on whether the screen came with the backlight. There is a remote chance that the display circuitry on the motherboard is faulty too. Try to plug a monitor into the VGA port and check to see if it is dim there too.
Feb 16, 2009 | HP Compaq Presario v3000z Notebook
Bluetooth device for compaq v3000
hi go to this link and chose the operating system you are runnig on your computer and all the necessary drivers would be displayed for download http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1817059&lang=en&
Nov 30, 2008 | Computers & Internet
What problem with the preserio v3000
i can help u if there is no display coming out its mean ur notebook VGA need to chang. its burnt bcoz off over heat.
Aug 06, 2008 | HP Compaq Presario v3000z Notebook
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Compaq Presario V3000T Notebook Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
