Nokia 1209 Cell Phone Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO RINGER SOUND - Nokia 1209 Cell Phone
Anonymous
Level 3:
President:
  • Nokia Master 2,246 Answers
  • Posted on Feb 14, 2011
Anonymous
Nokia Master
Level 3:
President:
Answers
2246
Questions
0
Helped
514745
Points
7384
Check your tone setting, confirm that the ringing is set to ringing
or may be the profile is set to silent, press and hold # button to release the silent mode
Ringer does not sound
  • Make sure the ringer is not muted or the volume is down.
  • Make sure that the sound file associated with the ringer exists.
Do you get any sound when you make a phone call to somebody?Do you get sound if you plug in amplified speaker?
Mar 13, 2015 • Cell Phones
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
1helpful
S5570 mic speeker ringer not work
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
1helpful
The sound quality is very bad
Hi, are you talking about the ringer or the ear piece sound.
Ringer: if the ringer sound bad it means that the ringer is damaged and will need to be replaced.
Ear piece: When you make calls and you people hardly you, It means that the earpiece which allows you to hear
people that is located at the top of the phone if faulty and needs to be replaced with another one.
Take care.
Aug 31, 2010 • Cell Phones
No sound in ringer
First You Go to Phone setting in Sound & Ringing Setting and check the Phone Ringing Setting if Ringing Setting alrdy OK
But No Ringing So
Secnd Option:
Your phone Ringer Default SO Please change Ringer
and Ringing Sound Problem will Solved
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
2answers
Ringer problem
it may be due to some small loose connection. remove the connections once and re fix them again.
2answers
Sound problem
good evening ! the problem of your phone is buzzer and speaker ,or the audio driver ic try to chagne that ! good luck !..god bless....
Sep 06, 2008 • Nokia 6600
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
