Question about Kyocera FS-4000DN Laser Printer
Hi error code: Call service 6020:0053103 Can't
Hi error code: Call service 6020:0053103 Can't find what this is anywhere
Posted by mm14 on
  • Mike Lyste May 19, 2016
    you have a problem with your fuser unit
Daniel Dollive
  • 315 Answers
According to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Posted on Nov 30, 2011
Canon Pixma MG 2170 problem. Error Code: 5B02 (Five-B-Zero-Two)
replace the cartridge, problem is with the cartridge only.
Jan 02, 2013 | Office Equipment & Supplies
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
I can't watch back my recorded cassette, on my camcorder? i'm getting an error message C31 23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Jul 24, 2011 | Sony Handycam DCR-TRV340 Digital Camcorder
Error code C:31.23
Feb 10, 2011 | Sony Handycam DCR-TRV145 Digital Camcorder
Will not rewind
Sep 28, 2009 | Video Cameras
When tape inserted "C:31.23" flashes
Mar 24, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Imagerunner 330S
this is the webb code for your fuser unit you have wo things to do in service mode 1st claer webb count touch counter misc webb clear key in that order then in this order function clear err ok turn off then on main switch
Dec 01, 2008 | Office Equipment & Supplies
Error code c:31:23
Sep 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Kyocera FS-4000DN Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
George Mclaughlin
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
