Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Our router works with the x box but nothing else. I don't know our IP address if I need that
Posted by avolk on
  • D-Link Master
  • 7,733 Answers
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Feb 14, 2011
Haw to configure fastweb router ?
Your router will come with an IP address.
You have to enter that particular IP address in the web browser to configure it.
If you don have the idea about ip address then,
Type cmd in the run box.
a black window will appear with a blinking cursor.
Now type ipconfig in the black window and hit enter.
it will show some address.
Note down the ip address default gateway, that is the ip address of your router.
Click here for a sample belkin router configuration.
Mostly all the router will have similar functions in the interface.
Sep 12, 2012 | Computers & Internet
Dap1522 ip config
Not sure what your question is, but if you are trying to find the router's ip address you can find it in the manual. Sometimes the ip address, default user id, default password is on a sticker on the side or bottom of the router. If you don't have the manual try the manufacturer's website.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
Maybe you want to know how to run IP Config so you can find the MAC Address of the router or Network Adapter. The Mac address in ipconfig will be the Physical Address (a series of 2 characters with a period or dash between them).
You need to get to a command promt (black window with white lettering) and type the command: ipconfig /all and press Enter.
Jun 05, 2012 | Computers & Internet
How to reset password
Look on the side and bottom of the router and see if there is an ip address that you would put into your internet browser to get into the router. It will be something like 192.168.1.1
Once you get into the router you will need to enter the user id and password then go to the Wireless Security Tab and change or enter the password.
If you don't know the ip address then search your manual. If you don't have the manual go to the manufacturer's website and view or download it.
Get online and got to www.google.com In the google search box type: "Zonet Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals. The manual will tell you the ip address and it will give you the default user id and password to get into the router.
Jun 02, 2012 | Zonet ZSR1134WE Wireless Router
Where is the WEP/WPA code on a Netgear router
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
Feb 04, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Trying to find a wap2 code to hook up xbox thru router. have no idea what I'm doing
If you can access router from pc/laptop, go into the wireless setup and go into security tab. here is where the code is located. Also check the bottom of the router. If you haven't changed the key, many routers have the key printed on the bottom of the router.
To access router, type in he ip address of router, if you don't know the ip address, follow this example.
START-PROGRAMS-ACCESSORIES-COMMAND PROMPT.
BLACK SCREEN WILL OPEN. Do nothing but type in ipconfig This will give you both the wireless and wired ip and the default gateway. You want to write down the default gateway. next type EXIT and the command prompt box will close.
Next open your browser (ie. Internet Explorer Firefox etc...) and type in only the default gateway ip address. example 192.168.0.1 there are no spaces and nothing added before the ip address. This will give you access to the routers access page. You may need a password to get into the router. Usually there is no username and the pw is admin. Then follow alone with what what written above.
Hope that helps.
Jun 02, 2011 | Belkin Wireless Surf Router (F7D2301)
I can't find the IP address for my 2wire wireless router and I don't know where to look for it.
  • Go to the Start menu, go to Run, and type "CMD" in the dialog box (without the quotes.)
  • 2 Now you should see a dark (DOS) window that looks just like the picture on the left of this article step.
    Without the quotes, type "IPCONFIG" and press ENTER.
  • 3 Now you should see some network information, along with the IP ADDRESS of your computer listed. The Gateway address is the router's IP address.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    May 23, 2011 | 2wire (2701HG-B) Wireless Router
    Port forwarding for model number F7D5301
    To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
    The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
    We do not currently know the default username and password for your router.
    Click the NAT button near the left of the page.
    You should now see a new menu. In this new menu, click Port Forwarding.
    Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
    Enter the port to forward into the Public Port and the LAN Port boxes.
    Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
    Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
    Put a checkmark in the Enable checkbox.
    When you're finished, click Save Setting near the top of the screen to save your changes.
    And that's it! You're done!
    Feb 05, 2011 | Belkin Basic Wireless Router
    Can't find the IP address of the Maxtor Shared storeage II drive.
    Download and install Wireshark(www.wireshark.org) on your PC. Attach the storage box and your PC and nothing else to a switch. Start a capture and you'll start to see all of the packets that your PC sees on its network interface. They will include a column for source address. The one that doesn't match your PC has to be the storage box.
    If this doesn't help, connect the two devices directly together(you'll need a crossover cable if your PC NIC doesn't support MDIX and try the Wireshark capture again - this WILL work. The first option is dependent on the storage box sending out some sort of broadcast packets which is likely but not certain.
    Jul 18, 2009 | Maxtor Shared Storage II 2TB Network...
    X box 360
    You can't get an IP address on the Xbox that way. You need to get an IP address from a device that works as a DHCP server such as a residential router. Connecting the Xbox to the PC will do nothing for you.
    Nov 08, 2007 | D-Link DI 514 Wireless Router (DI-514)
    How do I use the Remote Management feature on my router?
    Remote Management allows the device to be configured through the WAN (Wide Area Network) port from the Internet using a web browser. Step 1 Log into the web based configuration of the router by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Tools tab and click the Admin button. Step 3 Select the Enabled button to enable Remote Management. In the IP Address field type in the public IP address you wish to manage the router. Note: If you don´t know the IP address or wish to allow more than one IP address to manage the router then put an asterisk (*) in the IP Address field. You cannot enter an IP range. Step 4 By default the port used to Remote Manage the router is set to 8080. Change the port number by selecting the down arrow next to the Port Number drop down menu. Step 5 Click on Apply and then click Continue to save the changes. To Remote Manage the router you will need to type in the Public IP Address of the router in your web browser along with the Port Number (separated by a colon) you selected in Step 4.
    Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
    D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Mike
    k24674
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
